Results 1 to 10 of 10
    21st March 19
    Ottawa, Ontario, Canada
    dress tartan based on Logan/Maclennan tartan
    Hi serial kilters, ive made a dress tartan base on the Logan/Maclennan tartan that i want to make official. what are your options on it? thanks.
ID:	38980 Click image for larger version.
    Clan Logan Representative of Ontario
    https://www.instagram.com/clanlogan_ontario_canada/ (that's where i post my blogs)
    https://www.youtube.com/channel/UCVgTGPvWpU7cAv4KJ4cWRpQ
    24th October 18
    Perth Australia
    No preferences, they are both beautiful
    South African military veteran. Great grandson of Captain William Henry Stevenson of the Highland Light Infantry, Scotland (1880's) and brother to Infantryman Peter Mark Schumann of the 2nd Transvaal Scottish, South Africa (1980's).
    2nd January 10
    Lethendy, Perthshire
    16 Post(s)
    I'm assuming that the graphic on the left is supposed to be the standard Logan and that the apparent black lines at the edge of the red stripes are a result of the graphic programme you used.
    I'm not a fan of Dress tartans but if your clan wants one, and not having a chief, then you will need to get any 'official' design authorised by the Clan Society. With regard to the design, the single white overstripe over-balances the apearance.
    13th October 10
    Powell River, BC, Canada
    Exactly! The broad, white overstripe throws the rest of the tartan into the background, whereas, it seems to me, in established "dress" tartans, the white forms the background to the other elements. Even in the dreadful "highland dancers'" tartans, the white forms a background to the (often garish) colours of the main elements.
    12th January 13
    Michigan
    I would expect that perhaps the green would be replaced with white.
    Here's tae us - / Wha's like us - / Damn few - / And they're a' deid - /
    Mair's the pity!
    If I may offer one viewpoint on this.
    There are several steps that may, or may not, be involved in Tartan design.
    1) The Design
    Anyone can, and may, create a design for a Tartan. There are on-line Tartan designer programs and some are free (Just be sure to read the fine print). Some people have created hundreds of designs.
    What makes a design a Tartan, and what makes a design pleasing may be two totally different things.
    2) Listing a Design
    In 2009 the Archives of Scotland established "The Scottish Register of Tartan". This is now the 'official' place to list a new design.
    Before the Register you would list your design on "The Scottish Tartans Authority".
    Listing a Design, while called Registering, does not make it 'official' but simply says that your design - a. Is not copy of an existing design and - b. It conforms to the naming conventions.
    For example - When I listed my "Victoria, City of Gardens" Tartan, I had to send in a copy of a document from the City Council of Victoria, BC authorizing the use of the name of the city. Otherwise I would have had to call it simply "City of Gardens".
    3) Making a Design "Official"
    Again, using the "Victoria, City of Gardens" Tartan as an example. I had to submit a copy from the Victoria City Council showing that they had adopted the design as the 'Official' Tartan of the city.
    In the case of a Clan Tartan you would usually seek the approval of the Clan Chief.
    In the case of a non Clan Tartan the head or governing body would be who would proclaim the design 'Official'. The "official" US State Tartans have been adopted by the State Legislatures.
    4) Protecting a Design
    After the Tartan is designed you may wish to protect your design by applying for a Copyright.
    5) Have fabric woven in your Design
    After all this, you may wish to have fabric woven in your design.
    You contact one of the weaving mills and commission a custom run of fabric.
    Now, to your design.
    It is a common misconception that a "Dress" Tartan is "Dressier" or more formal. While there are some Dress Tartans that are different from the non-dress versions, the most common use of the word is normally just the same Tartan where one of the background colors is replaced with white to create a lighter, more feminine design, "More like a ladies dress".
    For example
    The MacKenzie/Seaforth Tartan, Modern Colorway.
    The MacKenzie/Seaforth Tartan, Modern Colorway, Dress Version.
    The Black Watch Tartan, Modern Colorway.
    The Black Watch Tartan, Modern Colorway, Dress Version.
    The Royal Stewart Tartan, Modern Colorway.
    The Royal Stewart Tartan, Modern Colorway, Dress Version.
    What I hope you can see from these examples is that the "dress' versions are easily recognizable as the same Tartan. Just one of the background colors has been changed to white.
    I wear the kilt because:
    Swish + Swagger = Swoon.
  7. The Following User Says 'Aye' to The Wizard of BC For This Useful Post:
  8. #7
    22nd March 07
    In Doors
    Not a fan. The whole point of a tartan is recognition; a visual que. The Logan tartan, as it is, listed as "modren" was first recorded by James Logan in his work The Scottish Gael in 1831.
    I personally see no reason to add another tartan so late in the mix. I'm not a fan of the current; albeit over half a century old, idea of colours, stripes, and patterns having any more meaning than, it is visually appealing.
    Read some of my old Society newsletter articles and you'll see where I'm coming from.
    https://electricscotland.com/familyt...ogan/index.htm
    Frank
    Drink to the fame of it -- The Tartan!
    Murdoch Maclean
  9. #8
    The "dress" design in the OP is an example of altering the sett by adding white stripes where there were none before.
    Then with numerous Royal Stewart variants there's the thing of keeping the sett the same but changing the ground colour.
    There's a third way one sees, and that is to neither add white stripes to the sett, nor change the ground-colour of the sett, but to keep the sett exactly as is but miniaturise it and place it in between wide white bands.
    To show how the original MacDonald sett hasn't been altered, but rather inset into broad white areas, here's a crop of the above photo.
  10. The Following User Says 'Aye' to OC Richard For This Useful Post:
  11. #9
    2nd January 10
    16 Post(s)
    The third version has the effect of making normally symmetrical setts, asymmetric which has been the cause of all sorts of problems over time.
  12. #10
    In my opinion what they've done with Dress MacDonald has the advantage of not altering the sett, but has the disadvantage of being unattractive.
    I think the asymmetry is a big part of why it seems ungainly to me.
    To make it symmetrical they would have to reduce the sett even more, having either a green/blue/green or a blue/green/blue portion of the tartan appear within the white areas. Or I suppose a cropped version of either of those to maintain the blue and green balance.
    I think the OP's approach gives a stronger tartan.
