Results 1 to 10 of 11
    25th September 13
    Marquette Michigan
    Young's Modern Sett Size?
    I've tried 3 tiems to use scotweb's contact form, but I never seem to get the "auto response" so I'm not sure if my questin is going through. SO I thought perhaps one of the members here could answer this question. What is the sett repeat size of the lochcarron 16oz Young's modern tartan? I just want to start planning ahead for a box pleat kilt I'd like to make when my tax refund comes in.
    24th November 12
    Tulsa Oklahoma area
    Interesting question.... 4.5 inches
    Just last week I received the tartan scarf, and tie in the Young modern that I ordered. They are gifts for my friend Scot Young, and his wife Linda.
    So...I've just now measured the "set" of the Young modern tartan in the scarf, and it's 4.5 inches between repeats. I wouldn't think that the weight of the fabric wouldn't have any thing to do with the set, and this "Young Modern" tartan weaves is 4.5 inches, or maybe more accurately (it looks like) 11.5 CM.
ID:	15968Click image for larger version.
    There you go....
    7th February 11
    London, Canada
    I'm absolutely no weaving expert, but wouldn't the weight of the fabric normally affect the sett size inasmuch as it would affect the size of individual threads?
    Unless this were compensated by "fudging" the thread count, I would assume that the sett size would rise and fall along with the weight of the fabric.
  4. The Following User Says 'Aye' to Father Bill For This Useful Post:
  5. #4
    24th November 12
    Tulsa Oklahoma area
    Hummmmm...that could be... I guess I could measure a 16 oz fabric and compare it to a 13 oz. and see? Hang on just a minuet.....
    You know it seems that your right! I've just now measured a 13 oz MacGregor modern tartan, and a 16 oz. MacGregor modern tartan. The 13 oz measured at 4.5 inches (just like the Young modern) and the 16 oz. measured at 7 inches.
    I'm guessing that it might be the same for Young modern, and I'm suspect that the question of the set of a 16 oz. young modern tartan is still unanswered, but it's getting "closed in on".
    Stan L.
  6. #5
    30th March 05
    Kentucky
    There are so many variables that determine sett size. Weight of the fabric/thread is a big one, but I'd wager the biggest would be the weaver.
    One weaver's sett size of a particular tartan in 16oz material may be 6" where another's may be 6.5", 8", 12", 16". There probably won't be that much variance, but there certainly could be.
    The best way to determine the sett size of a given tartan is to order a swatch of the exact material one is considering. Short of that, what contacting the merchant then asking here with the specific weaver, tartan, and size is best, but only responses related to that particular weaver/tartan/size will be pertinent.
  7. #6
    22nd January 13
    Lake Macquarie, near Newcastle NSW
    Quote Originally Posted by chasem View Post
    I know nothing about weaving, but I suspect that weavers produce different sized setts by applying varying factors to the threadcount of a tartan. Suppose the MacCentaur tartan has a thread count of Black 2, Pink 6, Black 4, Green 10, Red 2, Green 10, Black 4, Pink 6, Black 2. To my mind, a piece woven to Bk 5, P 15, Bk 10, G 25, R 5, G 25, Bk 10, P 15, Bk 5, in the same weight fabric is the same tartan, just the sett size is 2 1/2 times bigger.
    Sound, sound advice. I bought a piece of tartan directly from a mill, and they bothered not to answer my question on the sett size. I went ahead anyway, and it exercised my imagination about how to turn a sett repeat of 14" into a kilt.
    I'm satisfied my solution will be fine, once it's made. It may even be heroically adventurous enough to warrant posting a snapshot. But if you don't like surprises, always get a swatch.
    Grizzled Ian
    XMTS teaches much about formal kilt wear, but otherwise,
    ... the kilt is clothes, what you wear with it should be what you find best suits you and your lifestyle. (Anne the Pleater)
    "Sometimes, it is better not to know the facts" (Father Bill)
  8. #7
    25th September 13
    Marquette Michigan
    It had occured to me that the only folks to know exactly the size of the sett would be the waever. But I had hoped one of the rabble who own a Young's modern kilt made from the same weaver might be able to give me a rather close estimate. Certainly there must be a Young's about?
  9. #8
    20th January 12
    The Northern Appalachian Highlands of Southern Ohio
    I would suggest that you contact Lochcarron directly. They can answer your question easily and authoritatively.
  10. #9
    I was digging around the shop today trying to find if I had a small piece left over from the Young Tartan kilt we made a while ago. Alas we ship out any fabric and scraps left over to the customer.
    As you specified Lochcarron I can tell you that the what makes the fabric weigh more is the individual yarns are larger. This increases the size of the Sett in proportion to the weight.
    13oz is larger than 10oz and 16oz is larger than 13oz.
    I was then going to post a pic of the same Tartan woven in the same Tartan but I got tied up and forgot.
    If you can wait until tomorrow I will go back to the shop and do a thread count on the Young Tartan woven in 10oz. This will give a real good estimate of the Sett Size when woven in 16oz.
    I wear the kilt because:
    Swish + Swagger = Swoon.
  11. #10
    30th March 05
    Kentucky
    Quote Originally Posted by Grizzled Ian View Post
    Yes, you're absolutely correct. In the same weight from the same weaver, the two thread counts you mention should give the same tartan at 2.5 times bigger.
    What I meant from that part you quoted was that Lochcarron's 16oz Young modern sett and Dalgliesh's 16oz Young modern sett could greatly vary in size due to any number of factors - thread count, thread weight, etc., and likely would be at least a little bit different - enough that it wouldn't be beneficial to the OP to know Dalgliesh's, for example.
    I only add that because I felt like that part of my earlier post was a little vague.
