Results 1 to 10 of 30
Thread: tartan design
    27th July 09
    Greendale, Massachusetts, Unites States
    tartan design
    I’ve had the notion of building a tartan off of my assumed coat of arms, viewable here:
    http://www.americanheraldry.org/page...morial.HarrisS
    From what I’ve gleaned from this forum, I aimed for a tartan that was bold and distinctive while also being clean and simple. This is what I’ve come up with:
    I believe that the thread-count would be: P18 G54 W42 K6 W12 K6
    The major stripes of green and white come from the ‘vert doubled argent’ liveries of my arms. The white stripe bears three black overchecks, which reflect the three black crosses erminée in the arms. The green stripe bears a single pink overcheck that comes from the carnation in my crest. Excluding my bobcat’s fur, those four colors make up my entire arms.
    What do you think??
    Question about thread-counts: As far as this design is concerned, the thread-counts: P18 G54 W42 K6 W12 K6 and K6 W12 K6 W42 G54 P18 would both yield the same design. Is one notation preferable over the other?
    Stìophan, Clann Mhic Leòid na Hearadh
    Steven, Clan MacLeod of Harris
    Dandelion Pursuivant of Arms
    6th May 12
    Rochester, NY
    Initially...
    I like the tartan. Quite a bit, actually. The use of "pink" or "rose" (Wilson's maybe?) is a vintage nod that is underutilized.
    The proportionality of white to green (whichever may be your ground) may lead some to presume a Dress or Dancer's tartan...just a thought.
    As for the thread count, I think it may effect the Balanced Warp, i.e. ultimately what ends up at the selvages? And then, only half the count is required ("weaver's method" The 1819 Key Pattern Book, Peter Eslea MacDonald) : Half-sett...P9 G54 W42 K6 W12 K3 or K3 W12 K6 W42 G54 P9. How many half-setts across the width (hypothetically 6 1/2-setts @ 25" with re: reed, warp ends & epi gives 3 full-setts appx 8")...
    Balanced Warp:
    K3 W12 K6 W42 G54 P9 w/ pink on green at the selvage.
    P9 G54 W42 K6 W12 K3 w/ black on white at the selvage...which a weaver may not want to do, too light at the bottom.
    Figheadair, M.A.C. Newsome, RockyR, Slohairt, "Pleater" Anne, Barb T, Bonnie Heather all will have considerably more insight as to how the looms are set up.
    Perhaps you might PM one of the experts.
    Last edited by Domehead; 20th December 12 at 06:55 AM. Reason: Additional contacts
    Mike_Oettle's Avatar
    9th June 10
    Nice effort, Steven. I would echo Domehead’s suggestion that the large areas of white might suggest a dress or dancer’s tartan, but it is not necessarily a drawback.
    On the other hand you may like the idea of making the black stripes a bit broader, to diminish the domination of white.
    In the tartan I designed for myself (likewise derived from my arms) I similarly have three stripes in one colour across another colour (yellow on red).
    Mike
    [Proverbs 14:27]
    10th June 10
    USA
    I would actually make only the central black stripe broader - I feel that would echo the ermine spots in cross from your arms a bit better (as it would create a more substantial cross).
    Aside from that, I actually quite like it.
    27th July 09
    Excellent ideas! Thank you for the feedback. How's this?
    2nd June 08
    Repentigny, Qc, Canada
    Nice, I really like version 2.
    15th October 11
    Mallorytown, Ontario
    Quote Originally Posted by be da veva View Post
    I'm just trying to be the person my dog thinks I am.
    2nd January 10
    Lethendy, Perthshire
    16 Post(s)
    Version 2 is a better design however, I do like white based setts for kilts etc as they are too pale and more importantly (for me) non-traditional and they get dirty. If you are going to stick with large areas of white make sure that you specify 'ecru' (unbleached white) as the shade if you have the design woven otherwise you'll end up with something that will require sunglasses .
    6th May 12
    Rochester, NY
    Figheadair,
    Re: the OP's question about expressing thread count:
    Loomed on Balanced-Warp, if the half-sett is threaded K3 ... P9 or P9 ... K3, will this make a difference which colors end up at the selvage?
    If so, it does matter how the thread count is recorded K3 ... P9 or P9 ... K3, correct?
    Thanks for any information,
    Domehead, on behalf of.
    27th July 09
    perhaps more black, then?
    I wouldn’t have a tartan made that was pure white. I actually prefer the field of my arms (on which this tartan is based) to be more “off-white” than white.
    This one (v.3) now stands at: P16 G56 W32 K8 W8 K32
