Threaded View
 Barb T the little bits of hem in a... 5th September 08, 02:07 PM
 ardchoille Excellent post, Barb! I saw... 5th September 08, 02:25 PM
 turpin Knowing these little details... 5th September 08, 07:10 PM
 cessna152towser Thanks for the explanation... 18th September 08, 01:34 PM
 Bugbear I'm very thankful you posted... 19th September 08, 01:41 PM
 Bugbear Good deal, scottography. I... 17th January 09, 01:43 PM
 Bugbear Well... I think Pleater is... 25th January 09, 12:21 PM
 Bugbear That's great! When I put the... 18th January 09, 01:02 AM
the little bits of hem in a properly-made kilt
I thought I might post a few pics about the little bits of hem that are put into a properly made kilt so that nothing sags out from under the bottom of the apron. Tartan is Weathered Douglas, if you're interested. Oh - and this is Lochcarron tartan with one of the turned (tuck in) selvedges that's being discussed in this thread http://www.xmarksthescot.com/forum/d...757/index.html The selvedge is visible, but they did a pretty good job putting it in a good place in the tartan for it to blend as well as it could. But it is unavoidably darker in color than the other blocks. It's also stiffer than the rest of the tartan, so it's hard to turn up a smooth taper.
On the left side of the apron, the point of the deep pleat should be completely hidden, as below (red arrow).
In order to accomplish that, you turn up a little hem tapered from a max of about 1/2" at the point of the deep pleat and tapering to nothing at the edge of the apron and at the lap point of the apron on the first pleat.
On the left side of the underapron, the kilt bottom is also turned up a little to keep the point of the underapron edge from showing below the bottom of the apron. The hem starts about 9" from the edge of the underapron and tapers to about an inch at the raw edge, and the hem is stitched _before_ the facing is folded and tacked.
If you are putting a hem in a kilt, you turn up the hem an extra amount at the point of the deep pleat and along a taper at the underapron edge. Remember that, if you want to hem a finished kilt, you need to open up both the apron and underapron facings, turn the hem up, and then remake the facings.
By Barb T in forum Hint and tips from Barb T.
Last Post: 13th May 08, 07:27 PM
By Nighthawk in forum General Kilt Talk
Last Post: 6th February 08, 12:01 PM
By Coemgen in forum Kilt Board Newbie
Last Post: 20th August 07, 07:40 PM
By MacSimoin in forum How to Accessorize your Kilt
Last Post: 5th July 06, 10:33 PM
By Kilted KT in forum General Kilt Talk
Last Post: 16th April 06, 03:49 PM
