18th January 18, 11:04 AM
Sgian Dubh Styling
Hi folks,
I've recently decided to make a kilt (Morrison Hunting, knife to line) and its accessories. I'm attempting the sgian dubh and sporran. Many of the sgian dubh pictures I've seen show handles either in black or natural finishes. I'm hand carving a knotwork pattern onto an oak handle. I'm leaning towards a natural, linseed oil finish. However, I would like the knotwork to 'pop' a bit more - don't want my hard work to go to waste! I'm thinking on carefully painting in the negative spaces (colored black in my pic) in a dark brown to make the carving more apparent.
Additionally, I'm considering attaching a small pommel. I've not found a pommel cap in my preferred metal (nickel silver) in a style or size that works for a sgian dubh. Another option would be a dark-stained wood pommel in a thistle design.
Any thoughts? I'm fairly traditionalist, but ready to stray a bit. Would this be too showy, or look laughable? Thanks a million!
NOTE: The handle on the left has not been completely sanded. My craftsmanship isn't that poor
The Following 4 Users say 'Aye' to Seosamh2 For This Useful Post:
18th January 18, 11:24 AM
It's beautiful, I like it!
Moving thread to "Weapons" subforum.
18th January 18, 12:10 PM
I think solid colour infill would look tacky, but I'm sure there are stains that would make the details stand out and then linseed the rest. You can get gel stain for small projects like this.
Otherwise look up staining or glazing for woodwork. You could also dilute paint to a very thin consistency and paint it on until the crevices are filled. Once dry paint the whole thing with linseed.
As for showy, anything you're thinking of doing can't be any worse than the chromed plastic ones with coloured glass the shops sell.
The Following User Says 'Aye' to Damion For This Useful Post:
18th January 18, 01:59 PM
How about wood burning the areas you want to be darker? There are some very thin pyrography tips that are great for doing detailed work.
The Following 2 Users say 'Aye' to jumary For This Useful Post:
19th January 18, 04:11 AM
Not being an artisan in wood, I will not venture to suggest method, but I believe having the negative spaces darker would look wonderful.
Geoff Withnell
The Following User Says 'Aye' to Geoff Withnell For This Useful Post:
19th January 18, 08:17 AM
Thanks everyone for the input! I hadn't even thought of pyrography for the detailed work. I think that will do a wonderful job - and the tools aren't even expensive! Many thanks, jumary.
The Following User Says 'Aye' to Seosamh2 For This Useful Post:
19th January 18, 08:12 PM
 Originally Posted by Seosamh2
The band of knotwork at the bottom violates the traditional "rules" of how knotwork is done.
The lines always go over one, under one, over one, under one, and so on.
Never over two or under two.
Think about is as if you are plaiting cord.
If you don't have the Bain book I highly recommend it.
Some links
http://store.doverpublications.com/0486229238.html
http://www.maths.ed.ac.uk/~aar/knots/celtic.pdf
The Following 2 Users say 'Aye' to OC Richard For This Useful Post:
20th January 18, 04:40 PM
 Originally Posted by OC Richard
Woah, didn’t even see that! I usually check each line individually, and must’ve missed that. Luckily haven’t started on it yet. Thanks for the tip!
23rd January 18, 12:20 PM
if you want wood dyed a different color I would try one of the following:
for a subtle finish I would use a light cherry or early american stain
for medium finish I would use red oak, special walnut or red chestnut
for a dark finish I would use dark walnut or ebony
the problem I see with using staining is getting the stain color evenly distributed because you rub the stain to evenly distribute it and remove excess. wood burning would probably be better.
tact is the ability to tell someone to go the hell in such a way they look forward to the trip Winston Churchill
