22nd September 05, 08:19 AM
Ben Lomond
Taken from the David Marshall lodge, just above Aberfoyle.
Robert
22nd September 05, 08:23 AM
David, I cannot see a photo here.
22nd September 05, 08:31 AM
No pic
I can't see it either. You might need to make the file smaller.
22nd September 05, 08:34 AM
Can you see it now?
Robert
22nd September 05, 08:38 AM
No, not yet. How are you trying to put it in your message?
22nd September 05, 11:55 AM
Strange thing is I can see it OK, even from a different PC.
I did it in the usual way [im g]http://www.theplacewherethepicis/pic.jpg[/img]
Robert
22nd September 05, 12:01 PM
That's odd. I found the address in the source code and tried posting it, with the same result.
It's as if the code is not there.
Virtus Ad Aethera Tendit
22nd September 05, 12:25 PM
I did the same as BobC, and exactly the same thing happened. So then I went to Mike1's posting of many moons ago about posting pix, and found the following caveat:
Edit - The IMG tags are looking for a Location address, with an image extension, such as .jpg and not an .html address.
Perhaps the problem, then, is the "001.htm" identifier - maybe you're going to have to change it to a ".jpg"?
22nd September 05, 12:35 PM
I can see it with no problems.You may need to check your security settings.
22nd September 05, 01:26 PM
I can see it if I view Source on the page, pull out the URL for the pic, and run it in a different window. Just can't see it when I look at the page. Same browser and everything.
Is so crazy, as to make the ganglia twitch!
