22nd October 06, 08:10 PM
Fun in the Workshop.....
This weekend, I decided to make a kilt hanger for my most recent kilt.
I started by knocking apart a standard hanger for trousers that I purchased at a "dollar" store for $0.50.
Next, I took a strip of scrap wood from another project and ripped it to the proper width on the table saw.
Next, I resawed the board in half to I had 2 identical pieces.
The bandsaw leaves a rather rough surface, so I ran the pieces through the planer to get machine perfect faces on both sides.
Next, I cleaned up the edges with the router so I now had 2 flat, square, and smooth strips to work with.
Next, I cut the two slats to identical lengths (15 inches / 230cm) and cleaned off the tearout with a round-over cutter on the router and touched up the end grain with a bit of Nortin 220 grit sandpaper. Then I marked the hole locations for mounting the wire hook and drilled to the required depth.
Then I laid out the pieces ready to assemble.
I decided to use a polyurathane (Gorilla) glue for this application because of the materials. It requires moisture to harden, so I injected a bit of water into each hole. After inserting glue into each hole and a on the legs of the hook assembly, I assembled the new slats with the wire hook.
I let the adhesive set up for an hour or so and then selected a finish to seal the wood from moisture and give it a nice color.
I applied a couple of coats of finish over the next 24 hours and let it all dry thoroughly overnight. I then buffed up the finish with a bit of rubbing compound and ... Voila! ... a new kilt hanger is born ready to be pressed into use.
Fun to make and it works well.
blu
22nd October 06, 08:23 PM
Nicely done.
So are you going to start selling 'em?
22nd October 06, 11:00 PM
Easy when you have the tools, and you certainly have them Blu!! Nice job, it's impossible here to find good kilt hangers.
22nd October 06, 11:14 PM
Put me down for fifty of them Blu....
Ron
22nd October 06, 11:59 PM
excellent!
guid oan ya!
23rd October 06, 09:59 AM
Okay, you lost me at "ripped it to the proper width on the table saw." But seriously, nice work. If I tried anything like that it would probably look like a preschool art project.
Best regards,
Jake
[B]Less talk, more monkey![/B]
23rd October 06, 12:51 PM
I wish that I had all of that equipment. Maybe if I bought fewer kilts...
But then I would have to find time to actually make things!
23rd October 06, 12:56 PM
Well done and thanks for the photo sequence showing how to do it - though the title was misleading - I thought we were about to see some photoshopped pics!
23rd October 06, 12:58 PM
Nice job. Dangit, I'm gonna have to make some of these.
24th October 06, 06:14 PM
Nice shop tools. I'm jealous!
