Just received my new sgian dubh made by Mr. Rab Gordon of Scotland
Also got the blade portion for a sgian brew to be handled with a deer antler
The blades of both are made of swedish damascus steel
The handle of the sgian dubh is made of bog oak.
Lovely looking bit of kit you have obtained there. Look forward to seeing pics of the sgian brew when finished. Rab Gordan certainly does fine work. Cheers
The material I recieved from Rab for my father to use creating mine did not have a screw. He is going to have to drill a hole in the bog oak handle and the tang of the blade will be pushed inside. Challenge will be to have a narrow hole so the tension with the tang will hold the blade in place. He will probably use some sort of adheseive as well just as a precation. We are going with a different hilt on our project and that will need to be hand fitted in place as well so that it stays.
There is a reason that Rab charges what he does ... it is difficult work with the carving of the handle and then fitting everything for assembly.
What I found works well for those tang blades is two small holes drilled parallel with the flat of the handle on the drill press and then hogging out between them with a needle file or thin jigsaw blade. Good luck.
The pin at the end of the sgian dubh is sterling silver not a screw cap. The tang is very much like the sgian brew. I have yet to decide the shape and style of the handle for the sgian brew.
So far I think that I will drill a centre hole same size as the width of the tang and use a slimmed down jig saw blade to slightly widen the hole to the shape of the tang, to produce a tight fit.
Then I will add epoxy to hopefully fill and secure the extra space in the handle.
I may add a series of turquoise beads along the exposed side of the handle, no yet sure.
