Jacket buttons
So my wife is working on my argyll conversion and is sewing on the buttons. She also made my prince charlie. Her question is why three buttons, three on the sleeves three across the pocket flaps. I beleive three on the coat tails of the prince charlie. Anyone know? Thanks
Sean
I guess because there aren't two?
Quote:
It's all based on mathematics.
You see three is the first odd prime number, and the second smallest prime. It is both the first Fermat prime (2²º + 1) and the first Mersenne prime (2² - 1), as well as the first lucky prime. However, it's the second Sophie Germain prime, the second Mersenne prime exponent, the second factorial prime (2! + 1), the second Lucas prime, the second Stern prime. Three is the first unique prime due to the properties of its reciprocal. Three is the third Heegner number. Three is the second triangular number and it is the only prime triangular number. Three is the only prime which is one less than a perfect square. Any other number which is n² - 1 for some integer n is not prime, since it is (n - 1)(n + 1). This is true for 3 as well, but in its case one of the factors is 1. Three non-collinear points determine a plane and a circle. Three is the fourth Fibonacci number and the third that is unique. In the Perrin sequence, however, 3 is both the zeroth and third Perrin numbers. Three is the fourth open meandric number. therefore we use buttons in groups of three.
I hope that helps clear it up for you.
Who said tailoring wasn't a science!
OK-----Sew???:please:
MrBill
It's rooted in a philosophy similar to the yin-yang, while 3 is an odd number, there are two (even) sets of buttons to maintain harmony or balance.
Dang! You beat me to it. But I figured "at least I can start singing Three is a Magic Number" but then I see:
Quote:
Originally Posted by auld argonian
Dangit you guys you have taken all of my options, daaaaang yooooooou!
Best,
Matt!
Quote:
MrBill
The tongue-in-cheek point we are trying to make is just that it is what it is. Maybe there was some history in the military or elsewhere as to why three buttons was originally chosen, but now it's really just about the style. It just looks right I guess. If you want more or less than three buttons somewhere by all means...
Of course everyone will snicker at you for not knowing you're supposed to have three buttons. :lol:
It's aesthitics. The Japanese do it in Bonsai - Never use an even number of trees in a forest grouping.
It could have been five buttons, but three is the lowestm and therefore least expensive odd number. Thrifty eh?
:shock:
Quote:
:shock::shock:
Reason...
Three is the lonelyest number since the number one....
It has to do with fashon a long time age in a land far far away.
Quote:
… Scotland?
Quote:
Originally Posted by starbkjrus
:shock:
Dee, simply recall that Chef put the sui in sui generis. :D
string, I prescribe some time hanging out with the math geeks when they do whatever it is they do on Friday evenings.
The rest of you may wish to avoid asking leading questions when we're under the influence of our Geek Goddess Barb T.
Quote:
Why thank you sir. :lol:
Fashion and appearance - try four!
