Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    4th June 04
    Bolton, Massachusetts
    I believe Bear's PV kilts are 11oz, but I could be wrong. I have, however, lived outdoors for an entire season in a 4-yard Bear Kilt. Sub-zero temperatures, snowstorms, sleetstorms, thunderstorms, hailstorms. No worries.
    Andrew.
    5th September 05
    Chicago
    C'mon...ya GOTTA wear the kilt in these weather extremes! You GOTTA let the non-kilted know that this isn't some passing fancy but a serious wardrobe choice!
    Actually, I find the SWK Nightstalker comfy and warm in this weather...good lord, when I finally step up to a 16 oz wool unit it'll probably keep me going well into February.
    best
    AA
    Mr. Kilt's Avatar
    Mr. Kilt is offline Oops, it seems this member needs to update their email address
    17th February 04
    Manitoba, Canada
    Quote Originally Posted by KiltedCodeWarrior
    Al, I assume you only stood there long enough for that picture!
    What weight is the Bear PV? A bit concerned when the cold weather gets here, so if Bear's PV is in 13oz - 16oz PV, then I will feel better. Maybe not warmer, but better!
    Now if Jeff just finishes up the 2 lined PK kilts I ordered, I will be styling for the winter.
    Actually, it wasn't that bad. We stood there briefly, but my wife and I had about a 2-block walk back to the car.
    I don't know what the weight is on the Bear PV material, but it's not very heavy. At the time that was my only kilt. If I were to venture outside in those temps today I'd be wearing my Irish National heavyweight.
    14th September 05
    Space Coast, FL
    2 Thread(s)
    Quote Originally Posted by Andrew Breecher
    Andrew.
    Andrew, thanks! I had forgotten about your journeys when I posted this. I have found so far that as long as my torso is well protected, I don't have too much coldness except right at the exposed knees. I assume that was not a problem for you while moving, but did you wrap a blanket or anything around your knees when stopped?
    14th September 05
    Space Coast, FL
    2 Thread(s)
    Quote Originally Posted by auld argonian
    best
    AA
    Auld, heaven forbid, I never even considered not wearing it! Beyond "the question" the question I am most often asked at work is if I am going to wear the kilt during the winter months. My stock response is to point out where Scotland is to the north on a map versus where Chicago is and then add that I will be wearing 4-8 yards of material around my body and ask how much material is in the questioners pants?
    4th June 04
    Andrew, thanks! I had gorgottne about your journeys when I posted this. I have found so far that as long as my torso is well protected, I don't have too much coldness except right at the exposed knees. I assume that was not a problem for you while moving, but did you wrap a blanket or anything around your knees when stopped?
    Sometimes I would sit cross-legged (carefully arranging the kilt so I wasn't flashing my friends!), and cover my knees with my sleeping bag. Nothing like 800-fill down to keep you warm! Otherwise, as long as I was moving I had no problems at all. Hiking with a backpack generates a lot of body heat.
    Andrew.
    14th September 05
    Space Coast, FL
    2 Thread(s)
    Andrew.
    Andrew, that's what I thought. I would not worry about the cold if I were going to be doing anything even moderately strenuous. It is the out walking the dog, from the car to the office, etc times that I am concerned with. Luckily, most of those times are over quickly and back inside. Will have to decide whether I will take the kids sledding while kilted!
  8. #18
    4th June 04
    Oh, if you're moving about at all, I wouldn't worry about it. I was only chilly when I was sitting still outside in the freezing weather for three hours. And it wasn't because I was wearing the kilt - I got the sleeping bag idea from trousered hiking friends!
    Andrew.
