3rd September 06, 08:01 AM
A slight delay, but I'm on the job now....
The design, the buckle made of plastic modelling sheet and the pewter cast of it.
I'll now further shape the pewter casting...when finished, this will be used to make the production mold.
The buckle will be 8.5cm x 7.2cm, 4mm thick, 140 to 150 grams, a 5.5cm (almost 2.25") wide belt will fit.
The buckle will cost $12.50 +p&p.
I'll post pictures of the final result...polished and weathered versions...next week.
I hope this is what you have in mind
4th September 06, 07:26 AM
That looks great Robin! Perhaps a "smooth" version and a "Hammered" version?
4th September 06, 07:43 AM
It's not a good idea to hammer things made of pewter, but I'll see what I can do to give it a "rough" look
8th September 06, 10:27 AM
The "antique" version.
I didn't polish this buckle and left the small flaws as they are and gave it an acid bath. Looks pretty antique and handmade :rolleyes:
Since all buckles are handcrafted...each buckle will be slightly different.
The antique buckles receive a protective coating of clear varnish, the polished buckles will receive a layer of anti oxidation varnish and clear varnish.
Hope you like it
8th September 06, 10:38 AM
#15
Robin, That is great! Very nice work!!
8th September 06, 11:59 AM
#16
Wow, I am away for a little while, and look what pops up! Great looking Robin. I will be keeping an eye on getting one of these.
8th September 06, 04:47 PM
#17
I second that. cavscout made me a belt with a similar buckle. I haven't even seen it yet, becasue I'm in Chicago and it is in the mail, but no one ever died from having too many belt buckles.
8th September 06, 07:45 PM
#18
Originally Posted by Robin
The "anique" version.
I like it!!!
Mark Keeney
11th September 06, 12:10 PM
#19
The antique left and the polished right (pretty obvious )
The polished buckle still has some minor visual "grain"...It's handcrafted from start to finish and that's visible. A good thing imho...it has character.
I'm still in search for suitable metal wire 4mm thick to make the thorns from. I tried 4mm steel rod, but that's impossible to work with...can't bent it, way too stiff
The weathered buckle will cost $12.50 (4 in stock).
The polished buckle will cost $15.00, sanding and polishing is time consuming (2 in stock).
11th September 06, 12:14 PM
#20
Those are gorgeous Robin! I was wondering how you get the thorn on there
