Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    31st May 06
    Quote Originally Posted by The Wizard of BC
    If you don't mind a comment from someone who works with non-wool fabrics on a daily basis here are some points.
    First, and most importantly, PRE-SHRINK your fabric!
    Throw it in the washer on warm or hot water setting.
    Then into the dryer on cotton setting and let it tumble until completly dry.
    When you take the fabric out of the dryer you will have a pretty good idea what it will look like after every subsequent washing.
    After you make the kilt never, NEVER, wash in anything but cold water and NEVER allow the fabric to completely dry in the dryer. Always remove the kilt before the dryer has finished and while still slightly damp. (It should feel dry to the touch but you should feel moisture in the air when you open the dryer.)
    Hang up your kilt immediatly! Never allow it to sit in the dryer or the laundry hamper to cool.
    If there are wrinkles use a steamer. I much prefer steaming to ironing. In the shop we have a large industrial steamer but you can find smaller portable ones for reasonable prices and some have a finger like pleat attachment.
    Hang the kilt from two skirt hangers. One on the front aprons and one on the back. Use your hand to gently pull the pleat into shape while the heat softens the fabric.
    If you must iron, remember to align the pleats so the edges are perfectly parrallel. Never allow them to fan out. I find a piece of formica helpfull as an ironing jig. slide the formica under the pleat you are ironing to keep from messing up the pleat underneath.
    When I iron a kilt in the shop it takes only about 10 min. and is very easy.
    Then again, it's easy to iron my kilts because I sew down the pleats inside and out. The edgestitching is 1/8" from the edge of the pleat and keeps the crease very well.
    You can also press in an almost permanent crease by pressing not ironing.
    This involves not moving the iron over the fabric but putting the iron down, and leaning on it with your full weight and allowing the heat and steam to sink into the fabric. Then without moving or disturbing the fabric, allow it to cool.
    This pressing can take up to a minute for each iron placement. Each pleat can take up to 5 min. to crease this way. 5min X 32 pleats = 160 min or over two hours and that's just for the pleats. It's worth the time.
    I hope this helps. If you have any questions please feel free to PM me or send me an e-mail.
    Thanks.
    I've now changed how I plan to make the cotton kilt. I'm glad I am planning to use a machine now . . .
    As for the belted plaid, not a bad idea . . .
    I wonder how THAT would look with a Carolina Panthers NFL football jersey?
    24th July 06
    Quote Originally Posted by M. A. C. Newsome
    Different kind of fabric. The canvas kilts are made from an army duck cloth. Yes, they are 100% cotton, but it's much stiffer stuff and holds a pleat better.
    M
    Ah yes..... thank you for the info.
