Results 11 to 20 of 21
    Ah, the way2fractios Homage Kilt is gonna be:
    digicamo material, courtesy of way2fractious and his incredible stash of material! as well as his generous nature
    5 yards, knife pleated, full-width apron, sewn-down pleats
    I might line it with something hilarious, just 'cause he always lines his kilts, even the canvas knockarounds! I never line my x-Kilts.
    OK, what else did I learn? This is worth a thread to itself.
    9th August 07
    Triad Area, North Carolina
    I've been meaning to ask about this. How do you line a kilt? Do you just line the aprons? Do you pleat the lining?
    5th January 06
    Manteca, California
    Quote Originally Posted by Packhound View Post
    In kilts made traditionally, a liner is necessary to cover up the work done in the area between the hips and waist across the back. Although beautiful to a kiltmaker, to other eyes the cut pleats and stitched-in hair canvas would look awful - and it's scratchy, too! The liner has about a half-dozen pleats to accommodate the tapering of the tartan pleats on the outside.
    The liners across the aprons, from hip to waist also, cover and reinforce the strips of hair canvas that keep the tartan from stretching across our tummies.
    A traditional kilt is not lined below the hip line. In fact, the liner is hand stitched across the inside back at hip level, then folded up, pleated for the tapering, and hand stitched all around to finish.
    When the chance next arises, buy, borrow, or check out of a library the book, The Art of Kiltmaking, which details the procedure.
    Some contemporary kilts may be completely lined - for example, a denim kilt lined with flannel. But that's for those (of us ) who like to experiment with new things, too.
    Quote Originally Posted by way2fractious View Post
    In sewing terms, the shaping is perhaps more clearly described as having unsewn darts at the waist, as the lower edge is not folded but lies flat along the edge of the fell.
    5th January 06
    Manteca, California
    Thank you, Pleater. You are right about using the term "dart", which is the term Barbara uses in the book. Alas, I am not terribly skilled at sewing generally. Any poor skills I may possess relate only to making kilts, nothing else.
    9th August 07
    Sorry, I had a "duh" moment when I posted the question. Somehow I got to thinking about a lining further down. (Kind of like a lady's slip, but sown into the kilt, for lighter fabrics.)
    I have a copy of "The Book", and have been studying it. I understand w2f's explanation. Again, I had a "duh" moment and my mind went somewhere else. (Maybe I'll find it someday.) Thanks again for the info and sorry for the hijack.
    No need to sound contrite - I just thought I'd pipe up for the sake of clarity.
    Mind you if you'd had our Miss Ragg teaching you sewing at an impressionable age you'd know all the terms and be able to recite them alphabetically (probably whilst standing to attention). She was the games mistress as well.
    She probably mugs teenage gangs on the way to fetch her pension these days.
  8. #18
    5th January 06
    Manteca, California
    You know, I've been trying to figure out how to put in a detachable pink lace slip on an upcoming kilt as a small joke. Hmmm... maybe just baste in some lace ribbon on the inside of the selvedge...
    ...sorry for the hijack.
    Hey, no worries. I'm pretty sure Alan H was done with this thread anyway so, at worst, we only have a side conversation going. (...have to make sure he doesn't *accidentally* drop a caber on me at the next games.)
  9. #19
    I make kilt liners and I pin them into my various kilts with the smallest size safety pins onto the tape which is included at the inside of the waistband.
    The waist band is just a narrow strip binding the top of the pleats, not adding anything to the length of the kilt. I sew it to the outside of the kilt, then fold it over to hide the raw edge and then pin it over the tape which is laid on the inside of the kilt and sew it down.
    Basically it is a piece of fabric slightly shorter than the kilt with darts to shape it into the waist and long enough to stretch all the way around the inside of the kilt from the edge of the apron to the edge of the under apron - so when worn if the apron flies there are still three more layers of fabric between me and the public, and if the pleats do a flutter there is still a decent almost knee length covering.
    I make a small hem, and I would suggest rounding off the corners of the free edges so as to make it continuous on all three free sides.
    They are easy enough to make once you know the position length and width of the darts required for the shaping.
    If you don't have safety pins it is easy to tack it in place temporarily then remove it for washing.
    It should be tested carefully for length, too long and, as it will be closer than the kilt with the weight of the pleats to hold it might result in it catching in the bent knee when stepping over anything - out in rough country on a wet day it will strip the skin off the back of your knees in minutes.
  10. #20
    9th August 07
    Pleater,
    This is what I was picturing. I wondered if anyone did this. My first attempt at making a kilt was with a light, thin fabric. (Just to learn the mechanics.) But with a lining like this I might actually wear it.
    W2F,
    I knew that when I made my initial question that someone would go where you did. Thanks for not disappointing me. This place is always entertaining.
    Rob
  1. Replies: 58
    Last Post: 12th June 07, 03:44 PM
  2. Krakow Poland's new "Kilt Wearing Etiquette" (press release)
    By Fearnest in forum Kilts in the Media
    Last Post: 24th March 07, 11:37 AM
  3. Replies: 0
    Last Post: 12th March 07, 07:58 PM
  4. "Restricted" Tartan vs. "Unrestricted" T
    By Iolaus in forum Kilt Advice
    Last Post: 8th April 05, 10:29 PM
