18th September 07, 03:37 PM
Updates!
Well I finished the blade and sheath in time for the NH Highland Games this weekend, i need to afix a pin to the back of the sheath still but that's all that's left to do.
I've never made a wooden sheath before (or any sheath for that matter, having just modified other cheap ones to fit my other sgian dubh) I took the same wood that i had split to make the handle, and ground outa pair of depressions the shape of the blade.
Next I slid the blade in and out of hte two pieces clamped together to find the spots that the blade was still touching / rubbing against the wood.
Next once the blade fit in properly, I cut a piece of flexible magnetic strip, and marked inside the sheath where I wanted the magnet to fit with a small chisel.
Much grinding and filing later, I had created a 2nd depression which fit the magnet, and was deep enough to not interfere with the blade going in and out of the slot. I then superglued the magnet into place.
I then used wood glue in small amounts on the contact points between the two halves of the sheath and glued it in place, and let it stay clamped over night. This afternoon after I got home from work, I took the now dried sheath which was a rectangular block still, and spent a long time shaping it at my grinding station. The result being a matching wooden sheath for the mini sgian dubh. I'm not that happy with the result of the woodglue I used. It was supposed to dry clear/dark like the epoxy I used for the top part of the handle, but be stronger for the wood on wood application, however the resulting join line is infact a little bit lighter than the surrounding wood, and detracts from the overal look IMO.
"top" view in sheath
The blade outside and beside the sheath
The side of the blade and sheath
And lastly, the back side of the sheath (note it's flatter than the front side, because when I afix a pin to the back of it, it will be the side against the kilt)
18th September 07, 03:43 PM
I realized that I didnt have a 'top down' view of the blade and sheath, so here it is.
18th September 07, 04:06 PM
Nice work - and good results!
Truly one of a kind!
18th September 07, 04:44 PM
That looks great, excellent work, you should be very proud of it.
19th September 07, 12:58 PM
#15
looks great. You did good work. Is the blade sharp for use? Be careful with the pin. It might be too heavy and rip a hole in your kilt.
19th September 07, 03:48 PM
#16
the blade is very sharp, the pin doesnt weigh much at all. The problem i'm having with it right now is that it's top heavy, since the pin to attach it to the kilt is only on the sheath, but half the height and weight is above the sheath, it keeps trying to lean forward. I'm trying to come up with a good solution at the moment.
EDIT: I came up witha solution for now... i glued a pin to a strong magenet, which i'm pinning to the inside of the apron, which is holding the blade handle back yet letting it still be able to be removed from the sheath with ease. The magnet weighs as much as the pin itself though =/ Not the best solutoin but it works for now.
20th September 07, 08:10 AM
#17
Maybe a useful magnet site: http://www.wondermagnet.com/
By Buddha in forum How to Accessorize your Kilt
Last Post: 16th April 08, 11:18 PM
By demobud in forum How to Accessorize your Kilt
Last Post: 15th October 07, 09:34 PM
By Abax in forum Show us your pics
Last Post: 12th April 07, 06:17 AM
Last Post: 20th September 06, 02:54 PM
