Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Waste not
    24th August 06
    Kansas City Missouri
    Looks good. I would have expected them to be on the bias. That would give more stretch.
    Mark Keeney
    29th September 05
    Grand Island, New York
    They look good, and thanks for the idea - I don't know that would have occurred to me. I'll have to take a look at what's left over after I finish the kilt I'm working on.
    7th July 06
    Roswell, Georgia USA
    Quote Originally Posted by Mark Keeney View Post
    When all you have are scraps left from the making of the kilt, there's no way to do it on the bias, unfortunately. Still, they hold well.
    14th January 07
    with the wrap style flashes does there need to be any stretch? I understood these hold the hose in place because of the friction of the flashes wrapped upon. This creates a ring that will not expand. Tied above calf where the leg gets smaller this creates a small ring of flashes that can't expand over the larger calf.
    Conceivably you could use a piece of steel cable as flashes. You would need the right friction and flexibility.
    If for style/looks you wanted a set of these flashes on the bias. if you have enough material to cut four "squares" of tartan. Fold these in to a "tube" and sew together. These pieces should be long enough to hang down below the folded hose tops and go at least half-way up under the folded hose top. The connecting strap can be just about any material as long as it is ruff enough to create friction.
    27th November 06
    Norfolk, VA
    I ave made these before too. I find the edge looks nicer if you fold in half, sew the seam (make a tube) flip the tube right side out, press tube so the seam is centered (that's the back), sew a stitch 3/4" from each end and fray. Thats what I did and it worked for me, take it for what it's worth. ($0.02)
    7th July 06
    Unfortunately I didn't have enough material to make the tube - just about a 1.5 inch wide piece, hence the need to sew around use as is. I agree that the tube version would work better.
    7th May 07
    Chicago, Illinois, USA
    26 Post(s)
    Quote Originally Posted by turpin View Post
    You can sew down the long side and then use something like a wire coat hanger to turn it inside out, and then hand finish the ends.
    Animo non astutia
  1. California's Electronic Waste Recycling Act!!!...Huh?
    By Iolaus in forum Miscellaneous Forum
    Last Post: 22nd December 05, 11:07 AM
  2. A waste of money?
    Last Post: 27th August 04, 05:55 AM
  3. Something to waste some of your time....
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 29th May 04, 12:18 PM
