Results 11 to 20 of 29
    24th December 04
    Hopefully I'll get to see you guys in Flagstaff. Bring your practice stuff, we'll compare notes.
    8th January 08
    The Bayou City - Houston, TX
    Quote Originally Posted by Yaish View Post
    First, you'll need to get yourself some chain. You can buy any chain you like, in whatever length gives you the desired weight. Personally I went with a 30' tow chain, which weighs in right around 20 lbs.
    So, select your chain.
    I prefer a leather sporran belt. That sporran chain is likely to chew up my kilt fer sure. Forget it, dude.
    24th December 04
    LOL. That chain is for those of us who really stuff their sporrans.
    11th March 09
    Las Vegas, NV
    I just made these "practice" Items this last weekend. They worked like a charm! I changed a few things around but it works great!
    27th February 09
    Savannah, GA
    This is awesome advise on here. Now all I need is a training partner! Anyone in the Savannah, GA area wanting to help a rookie out! I can throw weight around all day, and reading about technique is not the same as someone showing you how to do it right. Same goes for everything else you do- proper technique only helps keep you from getting really hurt. Anyway, I'm really looking for a seasoned athlete to show me the ropes.
    I just moved up in the world with my 28'er. I stagger in pain when I see Mjolnir Hammer and the Old Celt's prices, though I don't begrudge them the $$ for their work.
    Here's what I did.
    I bought a $30 Old Celt 7-inch "D-ring" handle $30 plus shipping. I've been using that for several months, I just got sick of the hand cramps I was getting from the $11 Orchard Supply 4-inch galvanzied ring I'd been using.
    Anyway, I weighed that handle plus a good-sized shackle and 6 inches of 1/4 inch chain. It came out to almost exactly two pounds, plus a little bit.
    I then went down to the local metal shop and bought a 4 1/2 inch long section of 5-inch hot-rolled 1018 steel rod. This is rod stock that's actually 5 inches in diameter. There are data tables online that will tell you within 1/8 of an inch how much of each size rod to buy to get the weight you want. This was 25.2 pounds and $47. I got two little tabs of "L" shaped 1/4 inch steel extrusion, about an inch wide, each. I got them aligned all nice, clamped in a vise, and then drilled a 5/16ths inch hole through two of the flanges with a cobalt bit. Today I handed $20 cash to the welder to weld those babies on to the flat top of uber-thick steel rod. He did a nice job, the thing is *beef* and all up, the big rod, the two flanges, the metal inthe weld and the 1/4 shackle on the top comes to 25.8 pounds. The six inches of chain cost seventy-five cents...and then about $6 in shackles and I have a 28 lb weight that's within competition tolerances (0.2 pounds light, or less than 1%) for just about exactly $100.
    Mjolnir Hammers and the Old Celt charge $140 for a 28'r so I feel pretty good about this.
    26th August 09
    Independence, MO
    Well I've managed to make an adjustable throwing weight. My name is Chris and I work at a sheet-metal shop in Independence MO. I've been doing Strongman stuff for about 6 months and recently got interested in Highland Games athletics. (have done one NAHA meet, and going to another in Sept.) So, I decided that I was going to need an implement to practice with.
    Like I mentioned I work at a sheet-metal shop so I've got access to scrap plate steel and Laser cutting machines. One day we had a group of 5/8" HR PLATE parts come through the shop, that all had a 8" circular cutout. So, after talking to my boss and agreeing to pay him 10 bucks, he let me have the scrap circles. (11 plates in all) Thats when I made this beauty...
    I took a 7/8" bolt that I found laying around the shop, feed it through the holes I had programmed into the scrap plates, and topped it off with a crude fabricated "eye". Then I needed a handle so I had one of the night shift guys cut me out a 6" outside dia. ring out of 1/2" plate - I ground the edges so it was more comfortable in my hand. Connected the ring with 2 threaded connectors and there you have it - A "28#" throwing weight. (actual weight was closer to 32#) Total cost = $20
    Soon I started thinking, "I can make one even better..." Using a 3-D cadd system that we use at work I came up with a design that I think is pretty nice.
    This time I had to pay for the material and laser cut time, since I wasn't using scrap. But still got it for about $55. I decided to go with an actual eye-nut this time to make it stronger, and held it together with a 6" grade 8 bolt. I still used threaded connectors for chain, and a ground handle, but as you can tell I spent a little more time on this one... lol.
    AND this is an adjustable design. Take away a couple small plates, replace them with a few larger ones and suddenly you've got a 56# Heavy!! And you can use two threaded connectors to bring the total length to 17.75" or replace the links with a shackle and suddenly you've got a 14"ish set-up for WOB!!
    So, with hardware, material, labor, it came to about $75. Compared to the $320+ I could have spent buying a light and a heavy from somewhere else, ...priceless...
  8. #18
    9th April 08
    Kelso, WA, USA
    I saw your post on Nasga, great weights! My brother made ours out of round stock. He got the same deal on scrap. Looks great!
    James Gorley
    Highland Thrower
  9. #19
    11th July 08
    Detroit
    I've been drooling over these since I saw them on NASGA.
    Much better than the neanderthal toys I made:
    Now--The only things those bright shiny streamline babies need--are some mud splashes, grass stains and a bit o' flesh stuck to the handles
    [I][B]Ad fontes[/B][/I]
  10. #20
    26th August 09
    Independence, MO
    "Now--The only things those bright shiny streamline babies need--are some mud splashes, grass stains and a bit o' flesh stuck to the handles"
    HAHA Exactly! Thanks guys!!
  1. Sewing Practice
    By Jeremiah in forum DIY Showroom
    Last Post: 3rd February 07, 06:48 PM
  2. those cheap practice chanters
    Last Post: 13th November 06, 02:24 PM
  3. photo practice
    By Randy in forum General Kilt Talk
    Last Post: 20th April 06, 08:01 PM
  4. Practice chanter
    By porrick in forum Miscellaneous Forum
    Last Post: 13th April 06, 12:36 PM
  5. Practice chanter advice......
    By Blu (Ontario) in forum Miscellaneous Forum
    Last Post: 22nd November 05, 03:11 PM
