18th December 07, 09:11 PM
 Originally Posted by Ted Crocker
It sounds like paracord is good stuff to have around. I see a lot of... I think 514, paracord and in diferent colors too. If I do end up getting a thousand feet, it won't go unused around here. I'm still puzzled by the amount that will be left over after pulling the pleats together. I guess I could wrap it around my waist twice.
Paracord's thin enough and flexible enough (it really is some GREAT STUFF, Homer) that you could coil up the seven feet and slip it into your sporran, maybe even have a little wallet made for it.
I've thought about turning six yards of tartan I've got into a great kilt with a drawstring, and I've NEVER considered using anything but paracord. (aka 550 cord.) Add a couple of rolls of rigger tape/high speed tape/50 MPH tape/duct tape and you could build the Taj Mahal.
When American History is being studied a thousand years from now, we will not be remembered for Thomas Jefferson, Abraham Lincoln, FDR or Microsoft: we will be remembered for paracord and rigger tape.
18th December 07, 09:26 PM
That makes sense to roll it up. I plan on using the plaid in many different ways including hanging it on the wall along with wearing blankets for a little extra decorative insulation when not in use, so it's good that paracord is soft and won't be in the way.
18th December 07, 09:42 PM
Ted,
How bout some pictures or sketches of what you are planning and how it turns out. This sounds like it might be a good DIY thread.
Wallace Catanach, Kiltmaker
18th December 07, 10:02 PM
I really can't come up with pictures and drawings, see signature and profile, but I can describe what I want this plaid to do. I will look up a couple of things and post a description.
 Originally Posted by ChattanCat
Ted,
18th December 07, 11:04 PM
Here's what I want the plaid to do. I'm planning on putting a loop of thread or fabric where I want each pleat to be. The paracord goes through the loops, then the pleats can be drawn together kind of like opening a curtain. This idea comes from Matthew Newsome's albanach.org in an artical called "Did the Belted Plaid Have a Drawstring?" http://www.albanach.org/drawstring.htm
I will be using the plaid as a blanket/ sleeping bag by folding it in half width wise. It will be twelve feet long and so six feet when folded.
I also use wearing blankets a lot during the winter, so the plaid will probably be used in this way from time to time. I want to be able to put the plaid on fairly quickly because often I will be gathering up my blanket and going outside early in the morning to keep citrus and other plants from freezing. More often it will be to stop the cats from fighting in the un-heated end of my house.
Another way I will use the plaid is to hang on the wall either in the winter or summer for a little extra sound and heat insulation. I tend to only heat and cool one end of my thin walled house and I've found that hanging my wearing blankets and that type of thing on the wall makes things a little quieter and a little easier to heat and cool. Keep in mind I live in the desert.
19th December 07, 11:04 AM
After posting my reply suggesting paracord I thought...man, you're going to get trashed for that.
It is great to know that I'm not alone in my 550 mania. I never hike without about 100 feet of it.
Oh yeah...a roll of duct tape and four carabiners, too.
19th December 07, 11:23 AM
Ok, I am curious. What have you used the paracord, carrbiners, and duct tape for while in the woods, meadows, and mountains?
19th December 07, 02:20 PM
Duct tape repairs packs, raingear, tents and tarps. I use it a lot to mark trail areas that need work...wrap it around a branch and write instructions for the trail crew to follow. Boot repair.
With 550 you can make a dog leash for lost pets, tool hoisting lines when doing tree work, tarp support lines, extra tent fly tie-downs in high wind areas (try camping on top of Mt. Mitchell some time...the winds blow down the tents of the uninitiated on a regular basis. Pretty much every night someone loses their fly or their entire tent). I used 550 last year to lash two branches to my leg for a splint when I blew my ACL, then when I found that I kept banging my foot on the ground I rearranged it to lash foot to my backside so I could hop down the mountain more easily.
Carabiners are invaluable when making a z-drag to move really heavy objects (but this requires heavier line than 550 and a couple of Prussik loops, all of which I also carry when doing trail work). They're also handy for attaching gear to your pack loops, and having several hanging on your pack makes you look like you know what you're doing even if you don't.
How's that?
19th December 07, 06:36 PM
How's that?
That is quite a utilitarian piece of equipment. What the heck is a Prussik?
19th December 07, 12:14 PM
No, after I read up on paracord, I was thinking I need some of that for around here. A lot of times I use 100 test fishing line and different kinds of wire.
I don't hike, but it seems like a belted plaid might be a good garment for that.QUOTE=Tartan Hiker;462637]After posting my reply suggesting paracord I thought...man, you're going to get trashed for that.
[/QUOTE]
By Scottish Chi in forum Traditional Kilt Wear
Last Post: 15th June 08, 06:31 AM
By Robinhood in forum General Kilt Talk
Last Post: 10th September 07, 02:26 PM
Last Post: 26th September 06, 06:29 PM
By Andrew Green in forum General Kilt Talk
Last Post: 4th September 06, 02:26 PM
