Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    14th March 06
    Charlotte, NC
    Thanks for all the tips, folks!
    10th March 07
    It's been mentioned before, but I second 0000 steel wool to buff it, then I wife it clean with a damp cloth, then dry it then oil it. (I favour almond oil or coconut oil.)
    As for sticking it in the ground, that's something that always makes me shudder.
    In all the historical re-enactment groups I have worked with we were band from doing that because the swords had to stay away from anything that might corrode the blade and make it dangerous.
    If you must do that, heavily wax the blade with the sort of stuff you would use to wax a car.
    Once you've done that go ahead and make the hole for the sword with something else. Get a really long bit of metal just for the purpose. Dig it in deep, pull it out and gently ease the blade into the hole that's left. That way you will lessen any chance of it being scratched by little stones in the soil.
    Good luck with it all.
    23rd March 07
    Twin Cities, betwixt to be precise
    I currently use a scotchbrite pad and some mineral or gun oil to clean.
    Takes a bit of work, but should work fine. I wouldn't go with higher grit stuff until you have a firmer idea on how much you need to do and how you feel in doing it.
    [B]Barnett[/B] (House, no clan) -- Motto [i]Virescit Vulnere Virtus[/i] (Courage Flourishes at a Wound)
    [B]Livingston(e)[/B] (Ancestral family allied with) -- Motto [i]Se je puis[/i] (If I can)
    [B]Anderson[/B] (married into) -- Motto [i]Stand Sure
    [/i][b]Frame[/b] Lanarkshire in the fifteenth century
    [url="http://www.xmarksthescot.com/photoplog/index.php?u=3478"]escher-Photoplog[/url]
    20th November 07
    Ashland, Wisconsin
    I have a very highly engraved Union Civil War sword. Over the years it has dulled considerably. I'm a little shy about touching the blade, as the engraved camp scenes on the blade are so intricate. The entire sword need work, a new sharkskin grip, and the leather scabbard is breaking down. Should I try working on the blade or just try finding a good restorer?
    17th December 07
    Staunton, Va
    Sword Restoration
    Quote Originally Posted by Glen C View Post
    I would suggest that you send the sword to Crisp & Sons (Sussex Swords) for restoration. Ray Crisp, and his entire team, are all former Wilkinson Sword employees, and are simply the best on the planet when it comes to restoring a sword. That said, sword restoration is not cheap, and may well surpass the collectible value of your sword. If the sword is a family heirloom, you might want to consider having it preserved, rather than restored. If you go for preservation (on swords this is actually a deep cleaning process) you will retain the sword in much the same condition as when it was carried by your ancestor, rather than returning it to a near "unissued" state. (The blade, by the way, is etched rather than engraved on most 19th and 20th century military and civilian swords.)
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    I would second Rathdown's suggestion here of preservation, rather than restoration. I can't tell you how many period artifacts that came through the front door of our battlefield's visitor center that were ruined by "restoration".
    Todd
  1. Advice needed
    By Nighthawk in forum Kilt Advice
    Last Post: 28th March 08, 01:01 PM
  2. Kilt Advice Needed
    By McFarkus in forum Miscellaneous Forum
    Last Post: 22nd March 08, 07:50 PM
  3. Advice for Flying Needed
    By bangkok kilt in forum Kilt Advice
    Last Post: 23rd February 07, 03:46 AM
  4. Advice Needed
    By Dirka Skene in forum Kilt Advice
    Last Post: 2nd February 07, 06:34 PM
  5. Jacket Advice needed
    By Graham in forum Kilt Advice
    Last Post: 24th September 05, 02:03 PM
