Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    19th May 08
    Oceanside CA
    Hi Riverkilt, think I saw yours in the older thread linked in OP.
    The project is certainly dropping lower on the list of priorities
    Especially as one sister just passed along to me a box full of leather-working tools originally used by my father. . .
    Now all I need is time! Where can I buy THAT online LOL
    18th May 08
    Connecticut, USA
    That Dharma link is great! Thanks! It even has dyes for poly/cotton... maybe I'll get a couple mockers to dye navy and brown. I definitely need a couple more survivals to dye...
    Wow, I guess I'll have to do this over time, cuz it's gonna be expensive to buy all those kilts, and I've really been working up on getting a tartan kilt for a change... Decisions, decisions. I'll probably be dyeing my faded black survival soon enough anyways, it's not the right size for me so I don't wear it too often as it is and I'm not afraid of screwing it up.
    24th October 04
    Cincinnati, Ohio
    What I've done.
    Put rit dye into the washer, then set to regular wash (and I have had no problems with hot). Add UK after washer is filled. Sit there with a book, and every time the washer starts to drain, set it back to agitate. Repeat as necessary (probably 3-4 times depending on how dark you want - over an hour if you want really dark). Once you think it has been in long enough, go ahead and let it drain. Add about 1/2 bottle vinegar to the rinse. Then wash 2 more times (go ahead and use cold this time) with soap powder to make sure the loose dye is gone (adding fabric softener also fun at this point, it really helps with the wear of a Workman's). Hang to dry (it is the dryer that shrinks stuff not washing in hot).
    Note, unless they have changed thread, the kilt will dye, but the threads wont. Gives you kind of a levi's look.
    Adam
  1. Dying Wool?
    By Casper in forum General Kilt Talk
    Last Post: 2nd November 07, 03:59 PM
  2. Dying a Fur Sporran
    By AL-58 in forum DIY Showroom
    Last Post: 11th June 07, 01:19 PM
  3. dying a utilikilt
    By Kilted KT in forum Kilt Advice
    Last Post: 15th April 07, 06:30 AM
  4. Another friend dying
    By Graham in forum Miscellaneous Forum
    Last Post: 2nd November 06, 08:46 PM
