Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    10th July 08
    ... Make sure you use high quality 100% polyester thread (I use Gutterman, based on other's recommendation). I hear that "Dual Duty" these days is made from polyester only (and no cotton, as in the older dual duty threads).
    I'm using a all purpose/machine sewing thread in natural (no dyes).
    I did find out (after my previous post) that the bobbin was messed up so now that's fixed, all should be ready for tomorrows sewing.
    10th July 08
    Update:
    Almost done! Having an issue with "Tapering the Fell". It seems my rump and where the kilt will sit are the same measurements. Just to be sure I will have my wife measure me when she gets home (should be soon). However, if they are the same measurements, then what?
    I originally was going to do a knife pleat but went ahead and did the box pleat of the xkilt. So far it's looking good and can't wait to put it on.
    For those wanting to make your own kilt, be sure you are willing to put in the TIME and EFFORT because its a lot of time and a lot of effort and things will go wrong if you are new to sewing. Keep at it.
    19th May 08
    Oceanside CA
    Quote Originally Posted by MarkReaves View Post
    Update:
    Then you don't need any taper. Or, you could increase the rump measurement slightly (looser around the hips) which might be more comfortable.
    You've mentioned "taking this in" as you lose weight -- most likely you will lose more quickly around your middle than in the rump -- Pleater has some good suggestions for dealing with this as you remake the kilt to fit the new shape. However, cotton is less forgiving than wool when it comes to repeated alterations. Try to save enough fabric to make a new waistband rather than salvaging the old one, it will start to fall apart quickly when you are ripping out and re-sewing along the same line.
    Congrats on getting this far, and best wishes for the future!
    I hand sew the waistband even if I machine sew elsewhere - it is easier to remove and kinder to the fabric.
    Even if the waist and hip measurement is the same, unless you are very unlucky you are still going to have a rump to shape the kilt around, and a 'bay window' in front, which can be awkward to keep a kilt waistband on and level - though a sturdy belt helps.
    I found that I could reduce the size of the aprons and leave the pleats alone for some time as I shrank, and I put the extra fabric into large under apron pleats, which I found to be a very good design point to retain for subsequent kilts.
    Baroness Anne the mirthful of Fritterton on the Heath
  1. Kilt shops in Edinburgh - suggestions?
    By BruceBC in forum General Kilt Talk
    Last Post: 3rd July 08, 02:04 PM
  2. Kilt start to finish
    By Lyrd in forum DIY Showroom
    Last Post: 6th May 08, 10:21 AM
  3. About to start a kilt!!!!
    By Arlen in forum DIY Showroom
    Last Post: 20th December 07, 09:27 AM
  4. kilt suggestions
    By Norbydog in forum General Kilt Talk
    Last Post: 20th May 06, 01:07 AM
  5. Suggestions for a summer casual kilt.
    By David Thornton in forum Kilt Advice
    Last Post: 31st January 06, 08:51 PM
