Results 11 to 20 of 26
Thread: Hair canvas
    I have, in the past used a heavyweight non-fusible interfacing instead of hair canvas and it's worked out well. This stuff is generally available at most sewing stores, but make SURE to get the non-fusible stuff (you can't iron it and thereby make it stick to the material).
    29th March 08
    Lincolnton, NC
    would heavy denim work as well? just a question....
    14th May 08
    Slovenia
    Quote Originally Posted by AzureLupine View Post
    That is what I had in minde as possible alternative, too.
    29th January 06
    Asheville, NC
    Don't forget that denim continues to shrink with time, and that the blue threads and the white threads shrink at different rates. That's why so many folks caution against using it for kilts...I'm guessing that the same differential shrinking could occur if denim is used for reinforcing.
    17th July 08
    Fayetteville, NC
    I have to agree with what has been said. Most hair canvass is not washable. But (and I don't remember where she got it) my wife bought a bolt of a washable "hair canvass" made of nylon and polyester, woven, not felted like Pellon (tm), for use in the liturgical vestments she was making at the time.
    Yes, regular canvass can be used, or any other firm non-stretchable fabric. Of course it needs to be pre-shrunk if you are going to wash the finished garment. Since you have experienced seamstresses in the household, just explain what it is that you are needing the interfacing for.
    Sounds like your progress is good!
    14th May 08
    Slovenia
    I think I found possible replacement for hair canvas. Ribbon, 3cm wide which is used for sewing and hanging curtains. It's light, strong and washable. Will post a picture in the near future.
    ...but make SURE to get the non-fusible stuff (you can't iron it and thereby make it stick to the material).
    Yes, absolutely. And remember that, even if you don't iron it on when you're actually making the kilt, the minute you press the kilt, it _will_ be ironed on!! And you don't want that.
  8. #18
    14th May 08
    Slovenia
    So, here it si. Possible material for stabilizer instead hair canvas. It's used as a ribbon for hanging curtains and it's light, strong and impossible to stretch.
    Any comments, opinions? I've already used it on my kilt (not yet finnished).
  9. #19
    For my first kilt in DPM I used a strip of webbing that is similar, though probably heavier than your stabiliser, and that has been very sucessful.
    I am trying to remember what I did with the rest of it so l can put it into more kilts.
    You need to press that area of your kilt at a temperature the webbing can take, if it contains a man made fibre it will go crispy, or worse, if overheated. That means even if it is underneath other materials.
    I still recall with horror the time I decided to press an errant pleat on a cotton kilt and melted a Nylon belt - luckily onto the iron, not the kilt.
    Anne the Pleater
  10. #20
    14th May 08
    Slovenia
    Anne the Pleater
    Thanks! Good point. I must not forget this. Otherwise I do believe it's good replacement for hair canvas. And certainly can be washed on 40 deg. C. I was looking for hair canvas, but older sales ladies in shops did remember to have it far, far ago. this ribbon is very cheap (0.9 EUR for 2m).
    Will post some pics when my kilt is finished in separate thread.
  1. hair on goat
    By DWFII in forum DIY Showroom
    Last Post: 21st June 08, 07:49 PM
  2. Hair canvas - in UK?
    By Pete C in forum DIY Showroom
    Last Post: 24th December 07, 03:45 PM
  3. Horse Hair Canvas-> $6/yard-74" wide.
    By MacWage in forum Professional Kiltmakers Hints and Tips
    Last Post: 2nd August 06, 06:19 PM
  4. A wee bit of the hair of the horse...
    By glenmac52 in forum How to Accessorize your Kilt
    Last Post: 13th June 05, 11:35 AM
  5. Wind in the Hair
    Last Post: 24th December 04, 12:19 PM
