Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    27th June 08
    NoVA by way of RI
    Many thanks for the input. Just what I needed to get the ol brain workin again. I'm starting to picture each of the suggestions in my head and I must say....I'm going to need to get some more rosewood. I wanna try them all!
    23rd August 06
    Closest major city - Saint Louis, MO
    I'd be somewhat cautious about useing an oil finish on rosewood. Try it on a test sample first to make sure it doesn't darken the wood up too much and actually hide the figure.
    You might want to consider a shellac finish, instead. Or maybe just a matte wipe-on poly finish (or a semi-gloss wipe-on poly that you then rub down with a green nylon pad so as to remove the shine). Either of those should give you adequate protection (it is just a sgian dubh; not like you're going to be setting a drink on it or anything) without too much darkening of the wood.
    The shellac has the added benefit of being reversable (or easily repairable).
    Just something to consider from a woodworker's point of view...
    27th June 08
    NoVA by way of RI
    I've been using bee's wax. It's pretty quick and does a reasonable job of giving the wood a bit of lustre without changing the color of the wood too much. Apply it to the wood, let it sit for a bit, the buff with a piece of wool (I use an old hiking sock that lost its partner). It does require re-applying from time to time, but it's pretty easy to touch up.
    Quote Originally Posted by ehiker View Post
    20th June 08
    northern VA
    i don't know too much about waxes and shellacs but i've used tung oil for mahogony and maple necks on my guitars. rosewood can have a nice shine to it if all you do is fine sand paper, 00000 steelwool, and then buff. a little orange oil is all it really needs, at least for fretboards.
    30th September 08
    Cypress, Texas
    I would go with the Damascus bladee as well...
  1. Projects in the works.
    By Erisianmonkey in forum DIY Showroom
    Last Post: 15th August 07, 01:50 PM
  2. Barely Works?
    By auld argonian in forum General Celtic Music Talk
    Last Post: 11th March 06, 07:52 PM
  3. How the government works
    Last Post: 23rd February 06, 01:39 PM
  4. Let's see if this works
    By Brasilikilt in forum Show us your pics
    Last Post: 6th September 05, 10:08 PM
