Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    10th March 07
    That is a very, very sharp outfit. Good for you, Hector!
    3rd January 08
    Illinois, USA
    4 Post(s)
    Good on ya, you should be proud of your work. It's always nice to be able to sport what you have produced with your own hands. Great look, and as you say the price was right.
    Member Order of the Dandelion
    8th May 08
    Jacksonville, FL
    You ought to start making things on the side to sell at art festivals and such.
    11th May 08
    Louisville, Kentucky, USA
    Hector, that ensemble looks absolutely fabulous!! A very sharp outfit .
    28th May 08
    Trumansburg, NY
    A very impressive show of talent there Hector! A great job on your kit and you wear it well.
    24th April 07
    Duluth, MN
    Nicely cut!
    Kevin.
    Institutio postulo novus informatio supersto
    Proudly monkeying with tradition since 1967.
    Hector,
    You asked for comments / critique so I would like give you my honest opinion of your ensemble. First off let me say that I am very impressed that you were able to do your jacket and waistcoat conversions yourself, I lack the skill with a needle to do anything but sew patches on things (and the F-H.C.A.G. might have a tale or two to tell about how I messed up doing that!)
    Taking a look at your ensemble
    Quote Originally Posted by hospitaller View Post
    What works for me
    The kilt jacket, kilt, and hose all go well together. The grays, while not the same, are complimentary to each other.
    The red tie and red flashes work well as a counterpoint to the gray (I use red flashes and tie myself to similar effect when wearing darker colors/tartans)
    The sporran tassel colors. The white tassels give the simple black leather sporran a bit of flash that elevate it into a dressier accessory (a more elaborate/ brighter button on the flap would be even better)
    What doesn't work for me
    The waistcoat, while nice in itself, it just doesn't work color wise with the jacket or the kilt (it appears to have a greenish cast to it as opposed to the slate color of the kilt jacket and kilt). It also has a texture to it that stands out as being far too different from the kilt and kilt jacket. It is a nice waistcoat and I think it would work well with a tartan kilt.
    Belt and Waistcoat. Some may disagree, but I think you wear one or the other. Wearing both makes one's waistcoat look too short.
    The shirt. A simple white shirt or even better a pale blue one, would make your outfit look far more elegant. The check just doesn't seem very dressy and takes away from the dramatic flair of the very nice red tie.
    The sporran tassel length. They seem to long to me. I think they would look better if the ends didn't hang below the sporran.
    This is just my two cents, take it for what it is worth.
    29th April 07
    Columbia, SC USA
    Hector, you're looking very distinguished. Congratulations on your excellent work.
    I see Jamie's point about the color of the vest, but I'm not certain. Our perception of the colors may easily be skewed by the indoor lighting, the flash, and the camera's color characteristics. Take a good look at the outfit both indoors and in daylight to make a decision.
    The vest is really quite nice, as everyone has said. I don't have any problem with the vest matching up with the other grey garments. Somehow to me, the jacket, vest, and kilt look appropriate together---dare I say it, like something a Scot would wear.
    I wonder if the vest would look better without the blue added to the mix by the shirt. An afterthought: I scrolled the shirt up off my screen, and I really do like the combination.
    A white shirt might make for a more harmonious combination and would dress up the ensemble quite a bit: that gorgeous red tie would look terrific on a white shirt, very dressy! Alternatively, a white or neutral shirt with a green tie and flashes (or green hose) might turn the green shade of the waistcoat into an asset, "pulling" it into the whole outfit in a different way.
    Congrats again, and well done.
    - Ken
  9. #19
    Mr.Charles Anthony is offline Membership Revoked for repeated rule violations.
    4th June 08
    Maine
    Zwounds! You have done a very proffesional re-cuting of a commerical coat. With this level of competence, you should try some of the Patterns for these items. Then you can choose fabricks, styles to suit you desires.
    One thought, I would change the plastic buttons; the coat can be self covered buttons, or a contrast button. The weskit would do well with brass or pewter
    Thus the thoughts of
    Mr.C.Anthony
    Historical Tailor
    Member-Recreated 74th Regt.Argyle Highlanders
  10. #20
    4th June 08
    Maine
    Addium; Weskit Lenght;
    An original weskit was long enough to cover the waistband/ belt before it flared left and right. The inverted 'v' shape was designed to make acess to the breeches flap eaiser than fishing thru the long skirts of the earlier style of weskit.
    Even a 21st Cent. weskit, with its short circular hemline, looks short and dumb, when worn with trowsers, if it does not cover the belt line.
    Thus I would Ditto this advice to Kilt-o-philles: have yourt weskit long enough to cover the belt line, before the inverted 'v' starts, generally the last button of the weskit lies over the belt buckle.
    Would some care to enlighten both the Membership and I?: were not the original belts worn to have the buckles turned to the back or one side when worn? This was my understanding, and how I wear mine. Fancy, whoop skip, belt buckle plates are a Victorian and later fashion trend.
    Again, the thoughts of;
    Mr.C Anthony
  1. Should you read an entire thread before responding?
    By Panache in forum Miscellaneous Forum
    Last Post: 10th August 08, 03:19 PM
  2. USAF Celtic Ensemble
    By davedove in forum General Celtic Music Talk
    Last Post: 16th June 06, 08:52 AM
  3. St. David's Day Ensemble
    By davedove in forum Show us your pics
    Last Post: 6th March 06, 09:50 AM
  4. The Xmas ensemble...
    Last Post: 15th December 05, 02:55 AM
