8th December 08, 07:41 PM
Well, McElt, what's the purpose? I mean, I understand you'd like it softer, but is it really necessary?
I have several sporrans, both semi-rigid and soft leather. The softer ones are the "Rob Roy" style and are supposed to be droopy. I find the other ones are just fine the way they are and tend to soften some over time, but I don't mind the stiffness.
The one thing that does bug me are the tassels on the front of them. As I walk, it sounds like a column of troops marching...Thrump, thrump, thrump...Sometimes I'll pull them up and tuck them into the top. I'd cut them off altogether but it would leave slits on the front I'd have to cover up.
But I digress. If it isn't a major bother, I'd leave it alone. I'd rather put up with some stiffness than risk staining my kilt with some type of oil or conditioner.
T.
8th December 08, 08:21 PM
I tend to agree with Thunderbolt. I have several of each, too, and I find that I really like the looks of the stiffer ones best. The Rob Roy styles are roomy and very soft--one is made of elk hide--but they are quite slouchy looking.
I have a couple of military surplus sporrans that are stiff, but they always look pretty good, though they won't hold a lot. I'm not sure the even with treatment they'd be a lot softer since they're just not meant to be. I guess with enough work you could soften them up, but what's the point.
I think you might consider finding a nice, soft Rob Roy style for when you need to carry a bunch of stuff, and just work the other out however you like.
Good luck either way.
Jim Killman
8th December 08, 09:01 PM
I use Buffalo Butter. Great leather conditioner. You can google it up.
8th December 08, 09:12 PM
9th December 08, 08:11 AM
#15
Where did the idea come from that all sporrans should be soft and droopy like a Rob Roy? There's not a thing wrong with a sporran stiff enough to hold its shape.
As for the drumbeat of the tassles, some guys tack them down with a bit of silicone. I don't mind the drumming, myself.
Virtus Ad Aethera Tendit
9th December 08, 05:19 PM
#16
Thanks for all the responses.
I do like the semi-rigid sporran, but the part of my sporrans which should "accordian" out to stretch to allow me to stuff the sporran are very stiff, dry and brittle(?). I want to apply something to this part of the pouch to make it more supple. I think the buffalo butter or bear grease applied to the inside of the sporran should help me condition it.
I now am also on the lookout for the other, softer sporrans suggested.
9th December 08, 05:36 PM
#17
Any grease, oil, etc. that you apply to the inside of the sporran will rub off on anything you put into the sporran
9th December 08, 05:43 PM
#18
I would still say that perhaps you should look at the quality of the sporran you have it sounds to me that any sporran that a gusset that stiff is more than likely an in-expensive one. I recently purchased the style of sporran you are talking about from L&M it is a quality piece and the gusset came soft enough to expand. Sometimes you really do get what you pay for and there is just no getting around that.
9th December 08, 05:58 PM
#19
Originally Posted by georgeblack7
I was trying to think of some liquid more precious (ounce for ounce) than scotch... I came up with two, but only one exists: Your own blood and a serum that could cure cancer.
You don't have blood?
So far, in the last year or so, I have seen articles describing the destruction of cancer from leukemia drugs, vitamin D, as well as non-journal studies suggesting non acidic blood levels, capsicum, as well as ionic and tachyonic therapies.
And there was another one I saw in a pro journal that I forget what it was exactly, but was promising against breast and stomach cancer.
But then again... actually, my bad, the leukemia one was a cure for Aids, not Cancer. Really interesting study, they used a group of people that have a genetic resistance to aids to make the leukemia drug, and it wiped the aids out of the patient, as a side effect. Direct testing should be underway shortly.
10th December 08, 04:13 AM
#20
That's rather dependent upon the Scotch...I'd happily trade pint for pint for Laphroaig 15, Lagavulin 16, or Talisker 18.
By Ancienne Alliance in forum Kilt Advice
Last Post: 7th December 08, 11:16 AM
By tricam in forum How to Accessorize your Kilt
Last Post: 14th October 07, 03:52 AM
By KiltedTurtle in forum Kilts in the Media
Last Post: 24th May 06, 02:14 PM
By Viscaria in forum How to Accessorize your Kilt
Last Post: 9th August 05, 01:34 PM
