Results 11 to 20 of 29
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    I think we can agree, Jock, that ALL British Military capbadges used this type of fitting since Pontius was a Pilot.
    ...and his bodyguard was the Royal Scots! :mrgreen:
    Todd
    Todd
    Indeed they were.
    25th June 06
    Franklin, NC USA
    In my collection, I have a couple of badges that fasten this way. If for some reason the pin is missing, one can fasten a badge like this to a bonnet either by stitching it to the cap or fashioning a new pin.
    ----------------------------------------------[URL="http://www.youtube.com/sirdaniel1975"]
    My Youtube Page[/URL]
    22nd November 07
    US
    I have used a bent safetypin to hold the loop shank buttons on my jackets so the buttons can be removed and changed easily. It is not great for buttons because the pin can fold the fabric a little, and also show. It might work out for a cap badge though...
    I'm trying to come up with a different design of safetypin for the buttons that does not require the tiny buttonhole, and also does not cause the fabric to fold.
    I've also heard of split rings rather than cotter pins being used with that kind of shank on removable buttons.
    20th April 08
    Boston, MA
    The Navy - ah yes. What is they say? That trueism? I remember - "Old sailors never die - they only smell that way"
    I thought it was "Old sailors never die, they just get a little Dinghy!"
    Scotchmaster
    ALBA GU BRATH!
    That's even better than mine!!!
    29th December 07
    KENT WAQ
    Puffer explained one time that the shanks go through holes in the bonnet and the cotter pins hold the badge from inside the bonnet. It's much like removable buttons on a jacket.
    Best bet is to ask Puffer.
    OK, here goes
    1. The "old" style DoA Cap Badges all use the Loop/cotter Key ( Some of the "new ones use a "slider" = for the Doa "berets & Glengarrys
    Here is a picture showing some (see below it for explanation)
    2. The top = some of the fasteners I use. (left to right - Safety pin, Kilt Pin, Cotter Keys
    3. Cap Badges NOTE THE DIFFERENT SPACING, DIRECTION OF THE PINS & COMBINATIONS Left to right 2 horizontal (different spacing),Vertical,, Horizontal/vertical
    4. Lower group are some sporran Badges.
    5.Problems "mounting" on Cap the conventional way
    A. Holes MUST BE MADE IN CAP
    B. Once Holes are made you are "limited to those "Badges" that "conform", & as you can see ???
    6. Some suggestions on how to overcome the above.
    A. I make a backing In the first picture is on made of leather?/fur ( other materials also work but MUST be thick enough to compensate for the "shank" ( at least 1/8" iMHO) Rosettes also work GREAT !!
    I then run a cotter key through the loops (to secure it to the "backing & provide a connection for the "pin" I use on the inside (in this example akilt pin)
    B. Make a "Bow tie" (sorry I do not remember the correct terminology) & sew it to the cap (2nd picture top)
    C. If the cap is "soft & the loop/pins are short, then as in pic #2 right & pic #3 bottom. use pins from the inside
    D. Remove & Replace with the "fastener of your choice.
    I hope this helps.
    Puffer
  8. #18
    Forum Historian
    22nd June 04
    Hey, wow -- a "crucified moose" of the (51st) Highland Brigade!
    The Argylls refused to wear those things in Aden back in the 60's:
    http://www.britains-smallwars.com/Aden/700.htm
    Sorry...back on topic now!
    T.
  9. #19
    22nd November 07
    US
    Thanks, Puffer. I don't like the idea of putting holes in fabric for things like this, and I would think the hole would probably need to be stitched to keep it from un raveling.
    I have been looking into using a thin wire, like an high E guitar string, that is bent into a "U" shape. The wire should be thin enough to pass through the fabric, I'm thinking of buttons on a jacket, without harm to the fabric.
    The wire is then crimped together on the inside. You would have to use new wire with each change of item, but it would not require any holes. I'm guessing that thicker wire could be used on a bonnet, but the ends of the wire need to not be jagged in any way to go through the fabric well.
  10. #20
    29th December 07
    KENT WAQ
    T.
    YEP !
    ?????? was it because of the "crest' or the "TRIANGULAR" form off mounting ( an ABORTION DREAMED UP BY, IMHO, A "DESK JOCKEY" (this is not the term I want to use, but being a family friendly forum ?),
    Puffer
  1. Replies: 34
    Last Post: 11th March 09, 01:43 AM
  2. Sporran backs
    By Squeaky McMurdo in forum DIY Showroom
    Last Post: 29th October 08, 07:17 PM
  3. Button Identification
    By BonnieDundee in forum General Kilt Talk
    Last Post: 28th March 08, 10:35 PM
  4. Homemade Button
    By Freelander Sporrano in forum Show us your pics
    Last Post: 5th September 04, 03:15 PM
