Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    And, I'm sure that you know this, but I'll mention it anyway for others who might not. A kilt pin is just a weight to hold the apron corner down. It should never be used to pin the apron to the underapron!
    Oh dear no. Just think how heavy a kilt pin would need to be in order to 'hold the apron down' The kilt pin is a Victorian affectation, is completely unnecessary and worse, can do serious damage to your front apron when you catch it. Go pin free.
    My mother always pinned the two aprons together every time I wore a kilt - I suppose that was the reason for their demise, as I can distinctly remember the under apron being patched after I ripped it when the pin caught on a branch as I was climbing an apple tree.
    We had 120 of them, plus plum and pear trees, far too much of a temptation, even though none of them was on a dwarfing rootstock.
    With the big safety pin type you can make them a bit more secure by gently pulling the open pin into a wider V, which puts more outward pressure on the pin, holding it more firmly into the fastening.
    Another option is to fasten the pin then pass a strong sewing thread under the point of the pin several times - wrapping it around the double loop of wire, effectively closing off the pins exit route. Tie the ends of the thread to secure it.
  1. RK and direction of fabric
    By Kiltman in forum Professional Kiltmakers Hints and Tips
    Last Post: 27th August 09, 09:36 PM
  2. Jonesing in a different direction.
    By staticsan in forum Miscellaneous Forum
    Last Post: 18th January 09, 07:22 PM
  3. Pleat direction ?
    By sathor in forum Kilt Advice
    Last Post: 12th November 08, 02:57 PM
  4. Belt DIrection?
    By OFCJAX in forum Kilt Advice
    Last Post: 26th November 07, 03:54 PM
  5. x-kilt direction questions HELP
    By LadyGriffin in forum DIY Showroom
    Last Post: 13th October 07, 06:25 PM
