Results 11 to 20 of 35
    8th June 04
    Port Crane, New York
    Quote Originally Posted by seumasFinn View Post
    Unless he is quite tall, I'm pretty sure a 28 inch kilt is going to have excessive rise. Seems to me the army kilts I have were 25 inches for heights 5'11-6'0.
    Shortening it will take some care I think....if it is like mine, it is very heavy wool.
    I'm 5' 8.5" tall, and my "regular" kilts are 22" in total length. I'm thinking a military high-rise should be around 24" in length - max! - for my height.
    Brian
    5th November 07
    Toronto, Canada
    I have had a couple of PV kilts lengthened ( re-hemmed ) by an expert tailor for about $15 CDN. Final result was great. Nothing like asking one for advice. Only proceed if you feel comfortable with their response.
    10th June 10
    USA
    I know Lady Chrystel often hems the kilts she makes, and Barb T. has mentioned that a number of her band's kilts are hemmed and that you can really only tell the difference by handling the kilt.
    So, if it's done well, I'm sure there won't be a problem.
    16th January 06
    London
    Kilts can be hemmed, and fairly successfuly, but that isn't the whole solution really one thing comes to mind is that the length off the fell stitching will doubtless need to be adjusted, otherwise the swing of the kilt will be affected.
    Hemming by hand is slow but the result whould be fine, remembering that a good hard press on the inside so that the hemline isn't seen on the outside
    15th May 10
    Sydney, NSW, Australia
    Give this seller a look (link). The kilts are knife pleats but good quality. I just bought one and there is a review for it on here as well.
    15th April 07
    State College, PA
    The seller, bugpiper, has been selling kilts and kilt related items for some time. Might want to ask him the particulars, waist, hips, rise above the waist.
    Most kilts can be hemmed and you won't even notice. The wool really takes the crease on the bottom and the hem, if done correctly, won't be visible on the outside.
    Wallace Catanach, Kiltmaker
    30th January 10
    Brit, but now Western Canada.
    Woodshiel,
    I was also looking at one of this seller's kilts at one time, but was put off by length.
    Can you see on the pictures how far down from the top the buckles are?....give you an idea of rise.
    I gather 4" rise is quite possible on an older military kilt, and can look fantastic!
    Still, 28" sounds long!
    Talking to my Bonnie wee pal over the big loch recently, she also said kilts are often hemmed. Quoted how her dad grew up in kilts, ...hand me-downs, first shortened, then lenghthened, etc.
    When I was dealing with costumes it was not unusual to find a raw edge where some previous last minute fitting had been done with the aid of a pair of scissors and the edge was becoming a rats' nest of loose threads.
    There is a product which is a hot melt glue on both sides of a fairly fragile tape. It is usually one inch wide, but can be cut down into 1/3 inch strips and then a small hem turned up, pressed, and then the tape put in and heated under an iron to make a small neat hem.
    If you wanted to remove several inches from the bottom of the kilt and make a speedy single fold hem that would be the way to do it.
    14th August 07
    Halifax, NS
    I'll have to disagree to this and whatever Arlen refers to as a 'raw edge seal'.
    If you ever want the kilt hem to last and to keep it looking good, you should never use the above products.
    Raw edges should be enclosed to both prevent raveling and to give a 'finished' look. This can be achieved in several ways:
    -overcasting the raw edge, either by hand or machine. I would recommend hand overcasting as machine overcasting (serging) adds bulk. Then hem, but while sewing fold back the raw edge and do your stitching about 3/8" to 1/2" from the overcasted edge.
    -hem tape - sew the tape to the right side of the hem, having at least half the tape extending past the edge of the hem. Basically, an overlap join. Then, fold the hem up to the inside at the desired length, press, then hem the hem tape to the kilt
    -binding - using a folded hem tape or a double or single fold bias tape, enclose the raw edge inside the bias tape and sew. Then hem stitching through the bias tape.
    Of all the above methods, I would choose hem tape of a colour that tones with the kilt. It is very thin, doesn't add bulk and keeps the inside looking neat. You can also use silk, satin or cotton ribbon as hem tape.
    10th March 07
    I took mine to a tailor and asked for her to do a blind hem. Instead she just hacked the bottom on. Even with a raw edge seal (Which leaves a whitish stripe at the bottom of the Kilt) there are still fraying bits.
    I'm currently looking for someone to do a retaining stitch the whole way around the bottom to keep it in check.
    Good luck!
  1. shortening a kilt from the top
    By scotchmaster in forum Kilt Advice
    Last Post: 14th May 09, 04:54 AM
  2. Shortening a sporran chain
    By YoungMan in forum DIY Showroom
    Last Post: 11th May 09, 04:34 AM
  3. Shortening a Kilt
    By Tetley in forum DIY Showroom
    Last Post: 15th August 08, 11:44 AM
  4. Shortening Length
    By Southern Breeze in forum Kilt Advice
    Last Post: 19th October 05, 08:50 AM
