Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    I agree with Matt. And I have to say that a large man in kilt worn at the proper height (i.e., top above the navel) looks slimmer than he does in pants and slimmer than he would if he wore the kilt below the belly. Wearing a kilt below the belly tends to accentuate the belly, rather than camouflage it.
    If you can wear your kilt high and perhaps a bit longer than the top of the knee the longer fell - the sewn part at the back, will make the upper part of the kilt more stable and less likely to skew, slide or otherwise misbehave.
    The longer length will also give the illusion of more perfect proportions - it is just the way that our perception works.
    Just as larger ladies look more elegant in long gowns with high waistlines, a man of substance looks more dignified with more kilt coverage and a wide belt with shiny buckle.
    For sure have your kilt sewn up to your size. Things like bellies and butts make a big difference that you won't get off the rack.
    If you have a belly, like me, I'd forgo the belts - the buckles are murder when they jam the belly. Kilts straps work fine to hold up the kilt.
    10th February 10
    Vancouver, BC, Canada
    I'm 6'5" and 245, I also have a somewhat pronounce mid-rif, I have several different kilts, from a Utilikilt, to a 5yd custom casual kilt, and 8yd custom tailored tartan kilts, they all have different fits, and sit differently the two first mentioned fit similar to a pair of trousers, and the custom tailored kilt is fitted to sit as the kilt was originally intended to fit, up above the navel all my kilts are extremely comfortable and give a definate slimming appearance, the only issue I personally have is the way the sporran sits below the belly seemingly scrunching up the front of the kilt under the belly button, haven't quite figured out how to rectify this issue. I wear belts occassionally depending on the kilt, and have no issues with them.
    Although I do agree that a higher rise kilt, above the navel fits better and gives the feeling of better "coverage" and a pronounced slimming effect, depending on what your intention is for wearing the kilt, IE: formal, casual, around the house, I would concentrate more on the proper, traditional fit of the kilt, as I believe the kilt was originally intended as a simple garment intended for all size of man and easily is the finest formal garment for 'larger' frames.
    17th May 06
    Edinboro, PA
    A slightly different question
    Hi folks!
    My question is similar to the original poster's, however my size / shape is different. At #211 and only 5'7", I'm not exactly a "gentleman of size". However, my physical shape is more of a concern to me. You see, my pronounced waistline means I resemble an inverted cone (think 'funnel'), which in turn means that any clothing at navel height or lower will get an assist from gravity and my body-shape.
    I've been contemplating one of the military-rise Black Watch kilts that are currently on What Price Glory's website (here) .... I'd love to hear the opinion of the Rabble....would this work better with my body-shape?
    cheers
    Hachiman
    Pro Libertate (For Freedom!) The motto of the Wallace Clan
    When injustice becomes law, resistance becomes duty.
    14th January 08
    San Antonio, TX
    Suspenders (braces to our UK brethren).
    1st November 10
    South America
    Quote Originally Posted by ForresterModern View Post
    What he said...With a jacket or waistcoat no one will even know they are there...Or, if you want, it can give you another item to match/contrast with your kilt.
    Rondo
  8. #18
    28th April 10
    The Smoky Mountains
    My advice, get up early one morning, drive from KTown over the mountain (passing through fair Gatlinburg) and go over to Franklin NC to the Scottish Tartan Museum. Its only about a 2.5 hour drive, you get to see the mountains on the way, and have Matt Newsome measure and make your kilt. He's one of the best and he is basically in your backyard. I have never had a problem with kilts, leather, etc when measured by a professional, something I can't always say when I was measured by myself/wife.
  9. #19
    29th December 10
    Knoxville, TN
    thanks
    One more question: when I measure my waist or have someone else measure should I request at least 2" inches more for my hips because my waist is larger than my hips? I would think I would want the kilt to come out from the waist and not come in to my seat and hips. Thanks again for everyones feedback.
  10. #20
    30th June 06
    Lotusland, Canada
    If your waist is larger than your hips, the hip measurement could be the same when the kilt is made. That way the kilt will hang straight and not be pulled in.
    Gentleman of Substance
  1. Replies: 26
    Last Post: 26th March 09, 06:31 PM
  2. Modern kilts or camo kilts with lots of pleating?
    By jkruger in forum DIY Showroom
    Last Post: 27th January 09, 01:22 AM
  3. Traditional kilts vs. modern and casual kilts
    By Beery in forum General Kilt Talk
    Last Post: 7th September 08, 12:40 PM
  4. Larger than Life at the Douglas County Scottish Society Games
    By Andrewson in forum Highland Games and Celtic Event Discussion
    Last Post: 8th July 07, 12:11 PM
  5. casual kilts, work kilts, and nice kilts
    Last Post: 1st June 07, 01:51 PM
