Results 11 to 20 of 27
    Quote Originally Posted by AKScott View Post
    Dang it. I almost did that with mine. I was afraid the loose end of the inner apron wold sag below the bottom of the rest of the kilt.
    Is this a non issue, something that only works if you move the strap a little bit, or do you cut off the excess?
    I would say you could move the strap about 2" without concern. If you move it more, the edge of the under apron may feel uncomfortable on the back of the leg.
    The inner apron can be folded back on itself if neccessary. I think cutting would be a last resort. There is a thread somewhere here about reducing a kilt by 10". I think BarbT either started it or posted.
    15th April 07
    State College, PA
    Yes, I recall that post. The kilt was a band kilt and the kilt needed to be taken in because of rapid weight loss. The apron covered much of the pleats and altering the kilt was not an option because the kilt was owned by the band.
    Folding back the under apron would be a good idea, but it depends on the material. I tried folding back an acrylic kilt and it just didn't feel right and I don't wear it because of the fit and the material. I prefer to redo the under apron's edge by reconstruction. I would take off the top band for a few inches, remove the stitching holding the already folded material of the inner apron, refold the apron and restitch it back together.
    Wallace Catanach, Kiltmaker
    Hi guys
    Here's the post, where I moved the buckles 10-11" (yikes! But I defy anyone to argue that it's a bad solution!!!):
    http://www.xmarksthescot.com/forum/f...oo-much-59745/
    Yes, a kilt is a custom-made garment, and yes, the loops would be "off center" if you moved the buckles too much. But it's better in the long run to have a kilt fit (and I don't put loops on most kilts to begin with - not trying to start any arguments here ; ).
    Anyway, as Wally says, if you move the underapron strap, there's no need to cut into the kilt to move the left side buckle.
    And I agree with Wally - moving buckles isn't tricky - you have to be careful not to cut the tartan, but it's just a matter of patience. Much easier than rebuilding the whole darn kilt and a _bundle_ cheaper than getting a new one! And, if the loops look odd after moving the buckles, cut the suckers off.
    14th October 10
    Los Alamos, NM, USA
    Belt-Loop Relocation?
    Hi guys
    Barb T: Why can't you move the belt loops to re-center them, after you move the buckles?
    12th December 10
    Fairbanks, Alaska
    Quote Originally Posted by mookien View Post
    Well, you could, but the whole shebang is twisted around from zero.
    You don't need them, just cut them off ;-)
    I have done this more than once and I have never had anything twisted. If done correctly the back stays where it is and the two aprons move - covering more or less of each other.
    If this is hard to visualise, do it in reality. Place your kilt on your bed, as you would wear it - aprons covering each other, but not buckled up.
    Now take the outer apron and shift it over 1 inch and then do the same to the inner. The waist should be 2 inches wider - but the back has not moved at all.
    MacBean is offline Oops, it seems this member needs to update their email address
    21st October 09
    Valley Forge, PA (USA)
    ...I don't put loops on most kilts to begin with...
    Having one of Barb's kilts with no loops and another full-length kilt with loops, I have to say I myself find sporran loops of little purpose.
    14th October 10
    Los Alamos, NM, USA
    AKScott: Knowing nothing about sewing kilts, I don't know what you mean by "the whole shebang is twisted around from zero".
    Let me ask a two-part question differently and as a kilt wearer. If the belt loops in the back are off center (eg left-shifted two inches) and I would like them centered (ie moved two inches to the right), can that be done, and how difficult is it to do so?
    14th October 10
    Los Alamos, NM, USA
    Barb T: I think you answered my question. The loops on both my kilts are sewn under the top band. I hope they don't ever have to be moved. :-)
    12th November 10
    Central Kentucky, USA
    Which brings up the question...
    How much apron is too much apron? Obviously an altered kilt will not fit as well as one made to your (current) measurements, but it should still fit pretty nicely if the alteration didn't move things too much. So how much too much apron can you have before the whole thing just fits wrong?
    Kenneth Mansfield
    NON OBLIVISCAR
  1. Moving buckles - how much is too much??
    Last Post: 11th June 10, 05:00 AM
  2. Operation Moving Buckles
    By nh_maclean in forum Show us your pics
    Last Post: 15th October 09, 10:12 PM
  3. Just an eye note
    By Bill in forum Miscellaneous Forum
    Last Post: 8th February 07, 04:44 PM
  4. Another sad note ...
    By Derek in forum Miscellaneous Forum
    Last Post: 17th May 06, 11:46 AM
  5. just a note ...
    By awoodfellow in forum General Kilt Talk
    Last Post: 6th August 04, 06:46 PM
