Results 11 to 20 of 22
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    Re: Tartan of the month - December: What do you see?
    Quote Originally Posted by xman View Post
    Attractive sett. Excellent colours. Very Wilsons looking. Wonderful balance. It looks like five colours to me, but there could be a Yellow as well as a pale Green. Herringbone edge up top which appears to end in the Light Blue rather then the Dark Blue therefore breaking the sett right at the edge. Early to mid 19th century then? Have I got that right?
    Yellow yes but pale green?
    Herringbone - really?
    Early to mid-C19th. Why do you think that is the case?
    Are those staples I see in the top right?
    No
    It looks like there's some kind of stitching around the outside edge of the piece which I can't imagine a use for. The buckling of the fabric in the bottom corners is almost certainly caused by this.
    Agreed
    It also looks like it might be a lighter weave and not that large a piece. May we have the dimensions?
    From what I recall it's about 6x8"
    There are also some interesting little 'jigs' in the vertical weave. Not quite a full herringbone turn around, but perhaps just for one thread and then back to the established twill weave. I'm not sure if this is intentional or a function of the loom or something else.
    Ah. So what might it be?
    25th December 08
    Lotus Land
    This is my cognitive deficiency with the overlap which I believe I mentioned in an earlier thread. Yellow it is.
    AH, NO. It is the 'jigging' issue again although there are a few treads which run back the other way and then return. I should have looked closer.
    Mostly my mistaken herringbone interpretation.
    I've not a clue.
    14th January 11
    Langley, BC, Canada
    From the matching angles of the cuts on the sides, and the creasing across the middle, it looks like it was folded and stitched together, but not as a pocket or pouch as it looks stitched on all 4 sides. But it isn't stitched along the fold, and as the fold isn't a tight crease it may have been folded around some other fabric before being stitched down.
    We seem to be looking at the inside surface; from the holes/tears the top, darker part of the sett, with the tidy edge, looks like it got most abused, probably on the other side of the cloth.
    A double-thickness patch for the top edge of a worn or torn kilt apron, or a repair on a piece of upholstery?
    10th June 10
    USA
    Quote Originally Posted by Dale-of-Cedars View Post
    It actually looks to me like it had been folded into quarters since the crease on the left appears concave while the one on the right looks convex.
    Though that may have just been the way it was stored, not a result of its original function.
    26th November 08
    Ct
    Is it clan Chattan
    2nd January 10
    17 Post(s)
    It's often the case with old pieces that they were re-used so their original and later functions may be entirly different. It this case the later use of the material could have been for any number of things from clothing to unholstery. With such a small sample it will probably remain one of those great unknowns.
    Quote Originally Posted by MacAngus View Post
    Is it clan Chattan
    No it isn't.
    25th December 08
    Lotus Land
    The selvedge at the top appears to be barlycorn, but is probably just more 'jigging' and it also breaks the tartan sett with what looks to be white threads.
    Could the 'jigging' be some kind of thread counting marker?
  8. #18
    2nd January 10
    17 Post(s)
    It's actually standard twill weave but the alternating single and double bue and white threads makes it appear a little like plain weave.
  9. #19
    25th December 08
    Lotus Land
    There appears to be at least one, likely two intentional holes in the fabric at the top by the yellow lines. Could we have a closer look at that?
  10. #20
    2nd January 10
    17 Post(s)
    Looks like general wear and tear to me.
  1. Tartan of the Month - August: What do you see?
    By figheadair in forum The Tartan Place
    Last Post: 27th August 11, 08:39 AM
  2. Tartan of the Month - May. What do you see?
    Last Post: 4th June 11, 05:41 PM
  3. Tartan of the Month - April
    Last Post: 29th April 11, 07:41 PM
  4. Tartan of the Month - March
    Last Post: 28th March 11, 01:13 PM
  5. Replies: 7
    Last Post: 28th December 07, 04:11 PM
