6th October 12, 01:20 PM
making tartan shoes
Hey lads (and lasses)
Have any of you ever heard of covering a pair of ballet flats in tartan? I want to wear ballet flats when I get married and I'd love my shoes to match the tartan ties that the groomsmen will wear. Is this something that I could pay any of the kiltmakers to do? Or the DIY gurus? Or could do it myself?
6th October 12, 03:11 PM
Dont see why you couldnt do it yourself. Google images shoes quite a few flats that are tartan. Might take a bit of hand work but sure would be fun. Of course photos will be the only proof you did it.
6th October 12, 08:08 PM
yeah but Im scared to make a fat mess out of them
6th October 12, 08:37 PM
what tartan are you looking to use?
7th October 12, 09:51 AM
Try it with some plaid fabric of similar weight to your eventual tartan. Mess around until you are satisfied with results, then use that as the pattern for your final.
I assume you are looking to cover existing flats with a layer of fabric, not make the shoe from (excuse me) the ground up? Spray adhesive from 3M, available at craft stores, should do the trick for short-term use.
Or you could look at the "tartan" trainers that, I think it was Kinetikat? made using permanent markers! If your tartan is not too complex and involves primary colors (close to standard marker colors) you might give it a trial run on some inexpensive flats, see what you get.
7th October 12, 11:09 AM
Sydnie7, correct me if my memory if wrong, but, I remember 3M spray adhesive as having no forgiveness. Once the two surfaces come in contact it is hard to remove or reposition. I would think that an adhesive with a slower drying time might be better. This would give a little time to smooth out any wrinkles and to reposition if necessary.
Because I have it, I would use Tandy Leather's LeatherCraft Cement. Put the cememt on both the shoe and underside of the cloth. Position, smooth out and tape the edges to the sole and the inside of the foot opening. Allow to dry, remove the tape and trim up all edges. Once trimmed I might go back and apply a thin line of cement on all edge and work into the cloth.
If the shoes are relatively inexpensive I might get two pair. One to use as a test and the other incase the test pair did not meet your expectations.
Please post pictures of the process.
PS. I wonder if canvas pumps would work where you could put a line of reinforcing stitches along the edges of the tartan. Since the shoes will be covered in tartan cloth no one would see the base shoe's material.
Edit: - Whatever cement that is used make sure it is flexible after it drys. Something like epoxy will dry hard and crack as you walk and dance the night away.
7th October 12, 10:50 AM
MacMillan Old Modern
Thanks for the suggestions I want to get MacMillan Old Modern tartan ties for the groomsmen and I found some nice ones on a number of differnet websites. Then I thought maybe I'd wear dark green flats to match my maids but how cute would tartan shoes be? I thought pretty darn cute.
The only thing that would change my mind how how tartan looks with a lace dress. Might be a little too busy. I might just have to stick with plain green shoes.
