How To Improve Your Kilt Pins
Awhile back I read the following post:
http://www.xmarksthescot.com/forum/s...ad.php?t=77933
Dale's comments about kilt pins inspired me to come up with a solution to sagging, 'fabric unfriendly' kilt pins.
Here are two typical kilt pins.
And they have the typical pin on the back.
So I used a rotary tool with a cutting wheel to carefully cut the pins off. The metal was fairly soft, so the cutting was pretty easy
Then I used a fine file to get rid of the humps and burs.
I bought some quick-set epoxy and some nickel-plated brass tie-tack posts for this project. Do a web search for tie-tack posts and you should be able to find something suitable.
I used a grinding wheel on the rotary tool to fit the tie-tack posts to the cross and filed the edges smooth. Then I used the epoxy to glue the posts in place.
And here is the finished product after letting them sit for the epoxies four-hour set-up time.
The epoxy seems more than sturdy enough to hold the pins in place. Time will tell. Silver solder might be another option for connecting the posts, but I was concerned about heat discoloring the pins. I'm sure a reputable jeweler could tack the posts on with silver solder, but I don't trust myself to do it.
This probably isn't something you would want to do to your heirloom sterling-silver kilt pin, but I think it would be safe enough for most pewter kilt pins.
"Once you can accept the universe as matter expanding into nothing that is something, wearing stripes with plaid comes easy." - Albert Einstein
