Results 11 to 20 of 21
    27th June 05
    Altoona/State College, PA
    This sounds like the makings of a really nice sporran...I'd love to see the finished product! Good luck!
    21st November 06
    Margaritaville
    Study pictures in catalogs, then make one out of cardboard & duct tape; actually, make several. Fiddle with different shapes & sizes 'till you get it just the way you want it. A lot will depend upon the size of the paw itself. For durability, I'd glue & stitch the hide to leather; both the front and the flap, and I'd stitch a piece of leather onto the back to take an all-leather sporran strap; less wear on the kilt than chain.
    You've gotta post pictures of that when you're done!
    18th April 06
    Phoenix Metro Area, AZ, US
    Quote Originally Posted by Alaskan View Post
    I want to make a sporran out of bear skin, whith the bear's paw as the flap...
    Unless someone found a dead cub somewhere, I'd think that a whole bear paw for a flap would make one muckle big sporran.
    15th March 06
    Kalamazoo, Michigan
    I've not thought out making a fur sporran, but there are several different threads on the Do It Yourself forum here that might give you some ideas.
    I started by just tracing around a bought sporran. This works for the back and the folded over part. The front panel needs to be cut off shorter, and I would taper it in about 1/4 inch toward the top so that it is a little narrower than the back panel.
    If you made one up from normal leather first, I believe it would give you better ideas of how to make the important one. I've now made 4 and feel I'm starting to get the hang of it.
    If you find the weight of the claw on the front just is not enough, a magnetic clasp doesn't show on the front but gives you just a little more secure closure.
    Good luck
    Tom
    14th February 04
    Little Chute, Wisconsin
    That was from 2004
    28th October 05
    Rocky Mts.
    For a pattern ,
    find a picture of one you like on the internet
    print it out
    use a copy machine to blow it out to a size you like
    glue it onto pasteboard
    cut it out
    ONE WORD OF ADVICE;
    Be sure to cut the bear skin from the back side through the leather only and then pull it apart
    don't cut it from the fur side
    I'm an 18th century guy born into the 20th century and have been dragged kicking and screaming into the 21st century.
    We do not stop playing because we grow old, we grow old because we stop playing"
    27th October 05
    Queensland, Australia
    Quote Originally Posted by Caradoc View Post
    Just what I was thinking! It'd be one wild looking piece tho. Keep us posted on the progress Alaskan.
    9th January 06
    Los Angeles, California
    I made a sporran from a 65" black bear years ago and it turned out great. I just drew the template freehand but just slightly larger than the sporrans that I purchased commercially since I wanted it to hold my chain drive wallet if I was too lazy to switch all it's contents to a smaller wallet. I made a bare sporran first and then used contact cement to join the bearskin to it, my advice is to trim the bearskin after it is cemented into place on the finished sporran. You can't go wrong and cut it too small then.
    I had a problem with a closure device since I didn't have any idea what to use for a clasp because the fur is so thick but I used leather laces and a single claw from a giant Kodiak and it not only functions but looks pretty good and the Kodiak claw gets a lot of attention.
    Just expect a heavier than normal sporran and a lot of compliments and inquiries.
    Chris.
    19th February 06
    Tacoma, WA
    Bear claws by the boys??? You're living on the edge.
    9th January 06
    Quote Originally Posted by Irish in Tacoma View Post
    Yes, and while dancing close if I forget to slide the sporran to my hip it gives the term "Pawing at the ladies" a new meaning.
    Chris.
