Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    12th November 10
    Central Kentucky, USA
    Quote Originally Posted by Ethanintn View Post
    If any of you saw a coat of arms description hat read "sa. a fess between three cinquefoils (another cinquefoil pierced) ar.".Do you think the "(another cinquefoil pierced)" would be the crest,and would that just be a cinquefoil with a hole in it?
    I would think someone copied it wrong. Since no one seems interested in answering your original question, do you have a context for us?
    Kenneth Mansfield
    NON OBLIVISCAR
    6th May 12
    Rochester, NY
    The first paragraph of my first response attempted to answer the OP's original question. The OP had a follow up query to contextual information.
    12th November 10
    DUH!!
    Scott, I can't believe we didn't figure this upon first reading. The abbreviations ought to have given it away!
    Ethan, you are obviously looking for a blazon in one of the many compendiums of arms listed by surname. I don't see this exact phrasing in Burke's, which usually uses "betw." instead of "between" anyway, but I'm guessing this is what you've found:
    SURNAME, sa. a fess between three cinquefoils (another cinquefoil pierced) ar.
    What that means is that someone with that surname has a coat of arms which is sa. a fess between three cinquefoils ar. but that there is a record of another coat of arms for someone with that surname that is sa. a fess between three cinquefoils pierced ar.
    To give an example from my own surname. One of the listings in Burke's General Armory is "Mansfleld. Gu. a bend cotised betw. six crosses crosslet fltchee ar. (another, crosslets or)." This means there are records of coats of arms for people with the surname of Mansfield, one where the crosslets are white and another where they are gold.
    Kenneth Mansfield
    NON OBLIVISCAR
    12th November 10
    Bingo. I did find it in Burke's also.
    Wallinge. Sa. a fess betw. three cinqiiefoils (another, pierced) ar.
    So what that means is that these are two known coats of arms for people with the surname Wallinge. First you would need to find out just who these arms belonged to since there is no such things as "family arms" associated with a surname and then it will require a good deal of genealogical research to discover if you are descended from either of them.
    Kenneth Mansfield
    NON OBLIVISCAR
  5. The Following User Says 'Aye' to SlackerDrummer For This Useful Post:
  6. #15
    17th December 07
    Staunton, Va
    Well done Kenneth.
    [SIZE=1]and at EH6 7HW[/SIZE]
  7. The Following User Says 'Aye' to MacMillan of Rathdown For This Useful Post:
