Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
    1st March 04
    Lincolnshire, England
    Quote Originally Posted by Graham
    Mind you, I don't understand why this is the only site that Zone Alarm hinders me from viewing the images on, weird.
    Graham,
    I use the free version of Zone Alarm, and I have no problem viewing the photos. As far as I can tell, the only real advantage of using the pay-for version is that it tells you more about the software which is trying to infiltrate your system, and I don't care what it is as long as it is kept out.
    Rob
    Graham's Avatar
    Graham is offline Oops, it seems this member needs to update their email address
    4th February 04
    Tasmania, Australia
    What you say is true Rob, I bought it because i like to support good software that seems to serve me well.
    The real question is: why does ZA allow you to see the photos and not me? Must be in the settings somewhere. Bit over my head I'm afraid
    22nd January 04
    Southwestern Ontario
    I've had recommendations for both Z/Alarm and N.P.Firewall. The versions I've seen are about the same price so the decision will be based on features. BTW...Does anyone here run their dial-up connection through a router? I have one but have never used it.
    14th February 04
    Little Chute, Wisconsin
    Blu, unless you have a home network a router on dialup is just agravation. It cuts your speed. Honestly, I'd never waste my time with one on dialup, I'm impatient enough now
    22nd January 04
    Quote Originally Posted by bubba
    I have a simple 2 computer network set up with a hub but we only use it to transfer files. The rest of the time the hub is turned off. So far at least, dial-up has served my needs well and it's inexpensive. (my scottish side showing thru a bit there.)
    21st February 04
    Lewisville, TX
    First let me get this out of my system...I run Linux so I don't worry!
    Second. Zone Alarm keeps updating their stuff so if this is the newer ZA they may have changed some things from the older versions. The FAQ on the ZA site might give you a hint and if not you can submit a question and it might help someone else.
    RLJ-
    22nd January 04
    Quote Originally Posted by richardljohnson
    RLJ-
    Thanx, RJ... I'll check it out.
