5th August 15, 06:54 AM
 Originally Posted by NYClark
Aren't there wide black stripes running horizontally that are missing in the vertical? I really should look at it closely to see if the black is just hidden. But if it is hidden in one direction isn't that asymmetrical? I suppose being an engineer I think of symmetry as being absolute and I should be able to rotate the material 90º and have the same pattern, which I don't with the Clark (not really with the Royal Stewart either due to the value of the colors). I may need to be less literal. I was merely curious to begin with and I remain perplexed. I shall stop thinking about it, if I can.
To recap, symmetry is not about how the tartan looks, it's about how it was woven. Symmetric weaves can look asymmetric. That I can accept.
You've got it; symmetric weaves can 'appear' asymmetric. In this case, yours is definitely symmetrical.
Katia was on the right track. The visual inconsistancy in a symmetrical pattern is down to one of two things; either the way the light hits the 2/2 twill which can give prominence to one direction; or, that the cloth is warp faced (slightly denser) which was common in older cloth and helped make it coarser.
An asymmetric sett is one where the pattern repeats in sequential colours and is not mirrored at repeating points. That should not be confused with having a different warp and weft arrangement with will often mean that there are areas of wholly mixed colours. So, whilst warp and weft might both be symmetrical, the effect is not.
5th August 15, 08:30 AM
A good example of an asymmetrical tartan is my Modern Buchanan. You can see the repeat of the vertical red-yellow, red-yellow. If it were symmetrical it would be red-yellow, yellow-red.
Aye
CTBuchanan
5th August 15, 10:23 AM
And here's the symmetrical version of Buchanan
5th August 15, 11:57 AM
Is this what is referred to as "Old Sett"?
5th August 15, 12:40 PM
#15
Yes, but no . Here's the background to the various Buchanan settings
The Following User Says 'Aye' to figheadair For This Useful Post:
5th August 15, 04:49 PM
#16
Ah, but tartan can lead you down roads you never imagined . It is the most singular of fabrics and most confounding. Ah, but the joy of it all!
The Following User Says 'Aye' to ctbuchanan For This Useful Post:
5th August 15, 09:15 PM
#17
That's what Lochcarron calls it. But whatever it's called, I just love my new Matt Newsome box pleat, in this tartan, in Ancient colors. ;)
KEN CORMACK
Clan Buchanan
U.S. Coast Guard, Retired
Cuyahoga Falls, Ohio, USA
The Following User Says 'Aye' to unixken For This Useful Post:
6th August 15, 07:41 AM
#18
I finally get it, nice tartans by the way. I had thought symmetry was having the same pattern vertically and horizontally (mirrored on the diagonal). But you're saying the pattern can be different horizontally and vertically as long as the pattern is mirrored (reflected).
Thanks for the clarification.
Dean G. Johnson
University of Rochester
6th August 15, 07:57 AM
#19
Technically it can and historically it occasionally did but it is very unusal and the resulting difference would make the pattern not a proper tartan in many people's eyes.
