Results 11 to 20 of 41
    21st October 08
    sterling, ny
    I'm interested if I can get the time away. Not much of a drive for me.
    I'll say! You're really close!
    26th November 04
    Dayton, Ohio
    Steve,
    As I plan on taking your course this time I will bring my sewing machine. I will bring my Reliable steamer. It is the 1.1 Liter model. I will also have the steam pad you used the last time you were in NY. Since I am driving up I have room to bring those items.
    Mike
    24th September 04
    Mike,
    Would you pleas PM me with the instructions on how you made your pressing pad. It worked really great and protected Barb's tables really well.
    Forum Owner
    9th August 16
    Southern Highlands, New South Wales
    Mike,
    I'm in New South Wales, so the USA is a bit far for me, alas. But I would also be keen to know how to make such a steaming pad, as I was wondering how I was going to be able to lay out my plaid for pleating on an ironing board without it falling everywhere. Please please please?
    24th September 04
    Michael,
    A pressing pad is made from materials from your local fabric store.
    The top layer is called "Ironing board cover" It is a metallic type of fabric that resists heat yet allows steam to pass through.
    Under that is a layer of "Ironing board padding". This is just like it sounds.
    Both of these are available in in bulk from almost any fabric store. You can then custom make a table and cover it.
    If you wish a portable pad or if the table under your pad could be damaged by steam Mike added a layer made from a "Space Blanket" as a vapor barrier. This is one of the very light metallic looking things often sold in emergency kits.
    And finally on the very bottom layer he added some regular Poly/Cotton fabric.
    This was all bound around the edges.
    Forum Owner
    7th September 14
    Edmonton
    Michael A,
    I do not know of this pad they speak of, but I've been wondering the same thing. My intent is to put a coated cloth on the bottom to repel moisture - a picnic table cloth type item. Two or three layers of wool blanket - maybe a fleece layer and then a woolen layer; want a pad but not too mushy - and then a top cover of very good cotton. Heat/moisture down into the table top is a concern but I think (I think) two woolen layers over a moisture barrier should be able to absorb that, especially if the pad is large enough that repetition over any one area is limited. Would use a quilting stitch to keep everything aligned during use along with a good machine stitched edge. I might forgo the fabrication since I don't see travelling with it and simply place those layers on the kitchen table when its time for pressing.
    Everything I need is currently in the linen cupboard, less the bottom cloth. If I looked around I'm sure there's something in the tablecloth collection. Oooooohhhh, including a table pad that goes under our holiday table cloth (don't want to be sewing that one up, though)
    Or, what Steve said while I was typing that
  8. #18
    24th September 04
    Please be very careful about any plastic for a vapor barrier. Melting plastic is not fun and smells awful.
    Forum Owner
  9. #19
    31st July 13
    Rochester NY
    Kilt Kamp 2017
    Barb and Steve, I'm in and I'd like to Take Steve's class this time
    Can't Wait
    Mary Pollock
  10. #20
    31st July 13
    Rochester NY
    Sewing Machine and steam Iron
    Steve I can bring up to 3 sewing machines (one for me) and a steam iron a good one like Barb's. Ill be driving from Rochester, NY
    Mary Pollock
