Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    8th October 12
    Cornwall, Ontario
    For those who are interested, the instructions for the interior buckle and strap are on page 33 of the supplement in the free pdf. You don't have to wade through the entire supplement - just skip to page 33, and start with the section Attaching buckles and straps.
    But why would we not want to wade through the whole supplement? It has pictures of tartan and everything !
  2. The Following User Says 'Aye' to plaid preacher For This Useful Post:
  3. #12
    Too true!!!
  4. The Following User Says 'Aye' to Barb T For This Useful Post:
  5. #13
    27th January 11
    Matlock, Derbyshire, UK
    4 Post(s)
    I began to use the "Internal Left Strap" as the solution to a problem.
    Here are a few photos that I have used in the book "The Hand-Crafted Contemporary Kilt".
    The kilt in these photos is a hand stitched contemporary kilt with a 1" rise. (It also happens to have a custom lining that Barb hates.)
    On the right side the buckle is installed as normal.
    (The buckles of a Contemporary kilt are sewn by machine for added durability. They are sewn all the way though the outer Tartan fabric, through the floating interfacing, the stabilizer, and can be seen inside the kilt coming through the lining. If this kilt ever needs to be altered or re-sized after it leaves my shop this is a visual guide to the owner that the buckles and straps must be sewn all the way through to catch the internal strength elements and not just to the outer fabric.)
    On the under apron left end the re-located left buckle is sewn the same way as the right buckle.
    The outer apron strap is sewn just as it would be normally. (Please notice that I sew the straps on after the lining is installed.)
    Then, to insure that the left strap is positioned correctly I fasten the right strap into the right buckle - put the left strap into the same hole of the left buckle - and 'walk' the two aprons just as if the kilt were being worn - And can then mark the position where the left strap will be sewn.
    I can then sew the left strap using the same method I used for the right, outer apron, strap.
    Another consequence of the "Internal Left Strap" is it allowed me to extend the internal stabilizer strip the entire width of the kilt. My stabilizers run from apron edge to apron edge. Both buckles and both straps are sewn to the same stabilizer strip.
    This has proven to be very strong and durable.
    A few of my kilts have been worn on a daily basis for over 7 years and they show no signs of the fabric distortion that I see in kilts made in the traditional manner with the hole.
    Here is a kilt made by Gordon & Sons made in the traditional, military manner. This is an actual military kilt of The Canadian Scottish Regiment in the Stewart Hunting Tartan. You can see quite plainly that the under apron fabric has distorted over time due to the stresses of wearing it.
    And the left strap hole has failed and needed to be repaired more than once.
    And here is a Contemporary kilt using the Internal Left Strap method after 5 years of wearing on an almost daily basis.
    Where are the photos this post refers to, please?
