Page 2 of 2 FirstFirst 12
Results 11 to 20 of 38
    28th May 13
    Calgary, Alberta, Canada
    I have a hand steamer which does a great job of getting wrinkles out of pleats. I have also laid my kilt on the floor of hotel rooms and used the steam iron to remove the wrinkles. Do it from the inside first.
    A. A. Milne
    27th June 18
    Vermont
    I lay my poly viscous and wool kilts out and let them rest first by laying it flat airing it out in the inside. Then I lay it out on the apron side and let it rest with a book to get it into shape.
    20th August 17
    Boston, ma
    Quote Originally Posted by Clarke View Post
    Would folding my kilt around the book help keep the pleat while transporting or storing it?
    20th August 17
    Boston, ma
    Quote Originally Posted by Liam View Post
    I will make sure to do it from the inside and then go outside. Thank you so much!!
    20th August 17
    Boston, ma
    Quote Originally Posted by Manu View Post
    What I have done in the past for small pleat maintenance on my 16oz wool kilt is wrap a slightly damp wash cloth around my wife's hair straightening iron, the thinner ones with 1 inch wide arms, and set it to low heat. I pull down on the pleat from the bottom corner of the pleat to keep it straight and clamp on each pleat carefully and run it down. It has worked for me pretty well!
    I will try that too, thank you!!
