27th January 20, 11:11 AM
![Quote](http://www.xmarksthescot.com/forum/images/misc/quote_icon.png) Originally Posted by Tobus
My Balmoral from glengarryhats.com has a black lining, which also appears to be synthetic, like nylon or similar. It's a thinner lining material than the Mackie.
GlengarryHats lists their hats as being silk-lined. I ordered one a couple days ago, and it should be arriving on the 31st, so I guess I can report back when I get it - see if it's any different.
Some good insights in this thread. I appreciate everyone's help with this.
27th January 20, 11:37 AM
![Quote](http://www.xmarksthescot.com/forum/images/misc/quote_icon.png) Originally Posted by MichiganKyle
Thanks for the info! My first guess was silk, but I wouldn't have suspected that they'd use silk on a lower-budget bonnet. I'm surprised. That does explain it being thinner than the Mackie lining.
28th January 20, 10:37 AM
I frequently line mine with polarfleece, either fully, or with at least a partial hatband. It's also possible to retrofit a fleece band (or just a partial one across the front) by hand sewing. Contrary to what one might think, I haven't found that the fleece makes them much hotter in summer than a more typical lining or hatband.
I have a pdf pattern for sewing one from tweed or similar cloth, along with step by step photos and instructions in my Dropbox stuff. I normally build mine to lean to the left (unlike the usual trend). The reason is that I often wear one when target shooting a big Sharps buffalo rifle and worn the other way the hat bumps the ladder sight. The pattern's instructions tell how to switch things around if desired, as the hat pattern is not perfectly round and symmetrical. Feel free to download and play with the pattern if you want to try making one.
https://www.dropbox.com/sh/w9bonwwie...ySqwmf5ta?dl=0
The Following 2 Users say 'Aye' to Todd Bradshaw For This Useful Post:
28th January 20, 11:05 AM
28th January 20, 11:07 AM
#15
@ Todd Bradshaw
Very nicely done Sir.
28th January 20, 01:23 PM
#16
![Quote](http://www.xmarksthescot.com/forum/images/misc/quote_icon.png) Originally Posted by Todd Bradshaw
Very nice - even a scale for different hat sizes. That looks amazing. Downloaded. Thank you!
29th January 20, 02:44 AM
#17
I even tried one with a Cheviot tweed which matches one of my kilt jackets and using a strip of tartan for the hat band, the same way dicing is used. I'm not convinced that I'm sold on the result, but it was one of those "one way to find out if you like it" things. Once you start making them, they're pretty much dirt cheap and if you make one that you don't like, or which doesn't fit well, it is no big deal. On to the next one.
https://www.dropbox.com/s/d3lpscub55...re-9a.jpg?dl=0
The Following User Says 'Aye' to Todd Bradshaw For This Useful Post:
31st January 20, 07:04 AM
#18
GlengarryHats belmoral arrived. It's definitely lined, but with what I couldn't say. My guess would be some kind of polymer - maybe nylon or a polyester blend - based on the sheen and the pattern of faux "quilting" dots that appear to be stamped into the material. I'll see if I can post a picture later. Looks like it could use a good Jocking to soften it up a bit, but overall, it seems serviceable enough.
6th February 20, 09:33 AM
#19
I have a couple of balmorals--neither is a Mackie. Both have quilted linings with a silky-satin feel. i don't know what the material actually is.
I made a costume tam a few years ago to wear when running a race. I bought cotton material in a tartan print at Wal-Mart and used a red tennis-style terrycloth headband as the sweatband of the hat. I just cut a big roud piece, a similar size piece with a hole sized for my head, sewed them together and then attached the sweatband. I topped it off with a toorie I made using bright green yarn and the directions from the book "So You're Going to Wear the Kilt." I used vecro to attach the toorie, so I could remove it and throw the hat in the washing machine after a race.
It shouldn't be too hard for you to make something similar in another material if it would fit your needs.
Andrew
7th February 20, 07:53 AM
#20
![Click image for larger version.
Name: Balmoral 2020-02.jpg
ID: 38166](https://www.xmarksthescot.com/forum/attachment.php?s=95035d22b45585409ef53f77489d896c&attachmentid=38166&d=1581087209&thumb=1)
Picture of the inside of the balmoral from GlengarryHats
