Results 11 to 20 of 44
    24th September 04
    OK, first off you are not wearing this kilt the way it was designed to be worn.
    All of the iconic kilts are designed to be worn much higher. A kilt is one of the very few garments designed in a time when men wore their trousers at the anatomical waist.
    Unfortunately the kilt is one of those garments where the wearer must adapt to the design of the garment. This is one of the times when the garment does not adapt to the wearers preference.
    The top strap would be cinched in just under the ribs. The two inches of kilt above the top strap will cover the bottom of the short ribs in back and in front it will be about 3-4 fingers below the bottom of the breastbone.
    Reach around in back and find the bottom of where the pleats are sewn down. That should be right at the widest part of the hips or butt. Approximately where your hip joint is.
    And the bottom selvedge edge of the kilt should be just at the top of the knee cap.
    Forum Owner
  2. The Following 3 Users say 'Aye' to Steve Ashton For This Useful Post:
    18th December 19
    Japan
    Question
    Thank you for your reply.
    So here it is with the top strap cinched at the natural waist and the rise over the ribs. Setting aside the fact that the selvedge is too high above the kneecap, you'll notice that the front apron pleat still kicks out. Is the waist or seat size wrong? In the future do I need to specify a larger seat? Or should I just avoid ordering kilts from this maker?
    Last edited by Dreaghann; 20th February 20 at 09:10 PM. Reason: Added photos, modified questions
    24th September 04
    Just one more note when you wear the kilt the next time.
    The left side lower strap is totally decorative. Fasten it very loosely. If you look at the fourth photo you posted you will see the stress and distortion on the fabric from this strap being tightened way too much.
    Forum Owner
  5. The Following 3 Users say 'Aye' to Steve Ashton For This Useful Post:
  6. #4
    Even though you say you have it buckled high enough, it still does not look to me like the buckles are at your true waist. The top of the kilt should be 2" above your true waist (not 2" above where you wear your jeans, but 2" above your true waist). That would put the bottom of the fell (the stitched part of the pleats) at the widest part of your buttocks. Where you're wearing the kilt in the pics, the bottom of the fell is about 2" below that, which is one reason why the back looks so odd. That contributes to the "wave" (i.e., the pleats aren't lying flat), although it may be that there's too much in the pleats at the hips and not enough in the apron (i.e., the splits might be off, but it's hard to tell with the kilt not sitting at the right height).
    Having said all that, wearing a kilt at the proper height requires that the kilt flares above the buckle line - this allows you to buckle the kilt tightly at the waist and have the kilt actually stay there. It looks to me like your kilt tapers all the way to the top of the rise (i.e., it's smallest around at the top of the kilt, not at the buckle line). If that's true, it will be impossible to buckle the kilt tightly at your true waist and have it stay there. So you might not actually be able to keep it at the right height.
    Realize that the hip buckle is purely decorative and doesn't do anything to hold the kilt on. If you buckle the hip buckle tightly, it pull across the front of the kilt. So, when you put your kilt on, don't buckle the hip buckle tightly - buckle it so that the apron of the kilt hangs as it would if there were no buckle there. Also, the hip buckle also seems low to me, although it might just be because the kilt is too low.
    I would also not likely put as much flare in the apron edge, and I would curve it more so that, at the bottom edge, it's not pointy.
    Oops - sorry for duplication on some of the of ideas - I missed Steve's and Tobus' posts when I wrote the above.
  7. The Following 3 Users say 'Aye' to Barb T For This Useful Post:
  8. #5
    24th January 20
    Near Grand Rapids, MI, USA
    I just wanted to chime in and say: I'm finding the information in this thread phenomenally interesting. I wish I had known some of this before I'd bought my first kilt (and, really, my second one as well). There's a huge difference in fit between very small size differences in a kilt, and the pointers in this thread give a lot of insight into why.
    Nothing meaningful I can contribute to this, but please by all means keep expanding on this subject. I have Barb's book and have found it wonderful as well, but every time this stuff's explained, it's explained in different ways and helps to actually understand the "why"s. It's really valuable information for those of us with no clue about textiles and garment construction.
  9. The Following User Says 'Aye' to MichiganKyle For This Useful Post:
  10. #6
    18th December 19
    Japan
    Question
    It still appears to me in your most recent photos that it's not being worn at your natural waist. If you put your hands on the sides of your torso and push in just where your rib cage drops off, that's where the top buckles of the kilt should be (not the top band of the kilt).
    Thank you both for your replies and for continuing to help me with this. I'm very grateful.
    I was fairly certain that the top buckles were cinched in tightly just below my ribcage and above the hip bone at the fleshy part on the side where one can push in, but just to be sure, I've taken photos again. I cinched in the top buckle as far as it could possibly go with no remaining holes in the strap. Has it made a difference?
    Looking at the pictures of the kilt as advertised it's difficult to see whether flare in the rise above the top buckles is part of the design because of the jackets the model is wearing, but you can see the same model wearing (presumably) the same kilt without a jacket 5 min. 35 sec. into this video on how to wear a kilt: https://youtu.be/50rEIHC6lB0?t=335 To my eye it appears that there is no flare.
    Regarding the apron kick out, at the 6:00 mark of the video (https://youtu.be/50rEIHC6lB0?t=360), there doesn't appear to be any kick out in the model's kilt. I am no where near as muscular as the model, so perhaps that is part of the issue (although it should have been obvious to the maker from my waist, seat, and height measurements that I am no rugby player). At the 4:14 mark (https://youtu.be/50rEIHC6lB0?t=245), it's just barely possible to see the depth of the apron pleat as the model begins to wrap the kilt. It seems to be about the same depth as the other pleats.
    Of course, one day, I would like to be able to visit a kilt maker in person for a bespoke kilt, but for the time being, I'm limited to mail ordering given my geographic location (Tokyo). Any advice you could offer would be much appreciated.
  11. #7
    You can easily tell whether there is any flare built into your own kilt. Check any of the following:
    • Hold the kilt with the pleats facing you and the top of the kilt up. Pull horizontally on the two kilt buckles at the waist. Then, move your hands to the top band directly above each of the two buckles and pull. If the length between the two buckles is larger than or equal to the length at the top band, your kilt doesn't have any flare.
    • If the pleats continue to taper from the buckle line toward the top band, your kilt not only doesn't have any flare, it actually tapers toward the top, which is worse than no flare at all. The pleats really need to flare a bit from the buckle line to the top of the kilt.
    • Check the edge of the apron and underapron. The pleats should meet the apron/underapron along a straight, vertical tartan line from the buckle line to the top of the kilt. If yours has an apron edge that continues to taper, you have the same problem as tapering pleats. It's impossible for a kilt to have any flare at all if everything tapers toward the top of the kilt. Here's what I see in your kilt:
    At least some of the pleats taper all the way to the top of the kilt. It's obvious on the ones in the pic below:
    Apron edge tapers all the way to the top of the kilt (between the buckle prong, which should be at the waist, and the top band, you've lost what looks like almost 1/4" of circumference in this one place alone):
  12. The Following User Says 'Aye' to Barb T For This Useful Post:
  13. #8
    19th February 20
    Edinburgh
    Quote Originally Posted by tylerkinkade View Post
    The left pleat of my brand new Balmoral traditional 8-yard Scotweb/Clan.com 13 oz wool kilt's front apron does not lay flat (i.e., it sticks out):
    Robert MacDonald talks about this issue at 2:16 of his video and explains why he always waits to iron this pleat until he has the customer try it on for the first time (which obviously wasn't possible in my case):
    https://youtu.be/Ivv8hwr0TZE?t=136
    Is it possible to fix this by resetting the pleat with a steam iron? How would I go about doing that? Do I need to remove the original pleat first? If so, how?
    It could be that the measurements are a bit off but by the looks of the photo its a kicking pleat, it means the kiltmaker has not put the fold of the first pleat high enough into the waistband. There's a simple fix if you want pm me.
    Nikki
  14. The Following User Says 'Aye' to Kiltmakers Laird For This Useful Post:
  15. #9
    18th December 19
    Japan
    Quote Originally Posted by Kiltmakers Laird View Post
    Nikki
    I'd love to hear your idea, and I'm sure others reading this thread would as well.
  16. The Following User Says 'Aye' to Dreaghann For This Useful Post:
  17. #10
    19th February 20
    Edinburgh
    I will post up pics soon, I have been away from my workroom and have a few kilts on the go at the mo.
    Nikki
  18. The Following 2 Users say 'Aye' to Kiltmakers Laird For This Useful Post:
