Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    Defining what a tartan is is actually harder than one might expect. In common parlance (at least here in the US) we tend to think of any named design as a "tartan" and if the design is not named (and used primarily for fashion purposes) we say "that's just a plaid." However, this common usage does not actually reflect the historic meanings of either word.
    It is interesting to note that Gaelic has no actual word for tartan. The one that is used is breacan which actually means "speckled." Plaid is derived from the Gaelic word for "blanket" and really referrs to the garment (i.e. the belted plaid, or a fly plaid, or a piper's plaid) and not to the pattern. It's only because plaids are most often made of a tartan that the two terms have become confused. But it is quite possible to have a solid colored plaid.
    The word tartan itself derives from the French word tiretaine which seems to have originally referred to a type of linsey-woolsey cloth (a linen/woolen blend) regardless of any pattern. How the word came to be associated, in Scotland, with a specific pattern of cloth is not known.
    The broadest definition of "tartan" would be "cloth woven with a series of stripes in both the warp and the weft, or a graphic representation of such a pattern."
    Most of the time when you are talking about traditional tartan design you will have a regularly repeating pattern that is the same in the warp and the weft. When we think of traditional Scottish tartan designs, this is what we think of. But there are exceptions to every rule.
    The most notable here would be the new Welsh named tartans being created by the Welsh Tartan Centre. These are unusual in the fact that they have different warp and weft designs entirely. But there are even some traditional Scottish tartans that do this. One that comes to mind is the McKerrell of Hillhouse tartan, which comes from a portrait dated to the 1870s. The pattern is regular except that the red line of the warp is replaced with a yellow line in the weft.
    http://www.tartansauthority.com/web/...r=By+Tartan+No.
    I've examined some plaids (by which I mean the garment) from the nineteenth century that were hand woven, in Scotland, in unnamed tartan patters for fashion use that had irregular warp & weft.
    And some recently designed Scottish tartans, such as Coigach, have a different warp and weft.
    http://www.tartansauthority.com/web/...txtTartan=6570
    So, while we can safely say that most traditional tartans have the same pattern in warp and weft, and this is the usual characteristic of a tartan, there are exceptions to every rule.
    Aye,
    Matt
  2. #22
    INACTIVE
    26th January 05
    Western NC
    Coigach tartan
    Those of you reading my last message and clicking on the links to the tartans may have astutely noted that the Coigach tartan, as shown, appears to by a regular (warp and weft the same) tartan. And you would be right!
    However, the ITI software I'm using shows it as irregular. The three black lines on the green feild appear only in the warp, and are absent in the weft.
    Obviously one is incorrect, and at this point I couldn't say which!
    Aye,
    Matt
  3. #23
    Thanks for the info, Matt. I didn't know that _any_ of the official Scottish tartans had different warp and weft, and, if I had looked at the thumbnail of the McKerrell on the Tartan Authority website without having your information, I would have simply assumed that the repeat was bigger than the thumbnail could show!
    Barb
  4. #24
    Maybe the definition should be something like 'Tartan is a fabric made by weaving where the single coloured yarns are usually arranged in stripes in both weft and warp threads in such a way that they create a usually symetrical pattern of stripes and squares, dividing and intersecting in a regular squared manner, or a similar fabric which is so termed by common usage'
    Nothing which is subject to the whims of chance and error can be set in stone, and it is most likely the errors which drive the creative weaver.
    The rhythms of the tartan colours are very like the knitted patterns from the North - both the textured or 'damask' patterns and the Fairisle ones - and some from the Nordic countries.
    The stars and flowers are symetrical and square, and although striped in only one direction there does seem to be something fundamentally similar in their designs. There are several patterns which are considered to be related by one being an error in the other - particularly Shetland lace which is so full of interconnecting errors that it is difficult to find a correct description of a particular lace anywhere - particularly as the names change too as several knitters over the years might have made the same error and 'Aunt Fiona's shawl pattern' is also 'Cat's Paw' and 'Cara's Veil' - which I have just made up but that is how it works.
