3rd February 07, 11:54 AM
Barb, I have done a couple of right over left apron kilts and there is really no need to reverse the pleats. Everything works fine. In fact with the pleats facing right over left the apron looks quite good. The only problem I found is the right edge of the new under apron sometimes catches on the underside of the reverse pleat in a stiff wind or if you run or dance.
Just did a little sleuthing on kilt skirts, and the ones I found actually are complete mirror images. Not saying it can't be done the other way, but apparently people who make kilt skirts (which I don't, hence my ignorance!) typically have the pleats opening the other way. So, if I had to make a choice, I'd be likely to reverse everything, particularly if I were a left-handed person!
B
2nd February 07, 07:52 AM
Has she never handled one of your kilts? That's too bad. Hopefully you can find a home for that one.
2nd February 07, 12:59 PM
Barb, that is a great question! And I wish I had a definitive answer. It appears to be a bit heavier than my SWK heavyweight Weathered Lamont, if that tells you anything. It also seems to be heavier than the last batch of XMarks, which was 14oz. I believe? Thos are the only 2 I can compare it to that might give you an idea (although I just spent 10 minutes in my closet fondling the scrap piece in one hand while I compared it to all my other kilts with my other hand!). I suppose I could try to lay a yard on my postage scale, but that is probably only going to be a very rough approximation.
3rd February 07, 06:21 AM
Huh - I'm surprised - tartan with such a small set is typically light weight tartan.
You could try telling her that, until you cut out the bulk at the waistline where the pleats are, it will feel bulky, even if it's lightweight tartan. This is particularly try in the case of this kilt because the pleats are so deep and there's so much overlap. Once that's done, and the kilt is actually buckled on, it won't feel heavy or stiff at all.
B
2nd February 07, 09:20 PM
My g/f wanting a pink and black plaid mini kilt now, thanks KCW. lol
Knowlege is knowing that a tomato is a fruit; Wisdom is knowing not to put it in a fruit salad
 Originally Posted by Dreadbelly
If people don't like it they can go sit on a thistle.
By wsk in forum The Tartan Place
By Eric T in forum Kilt Advice
Last Post: 26th May 06, 04:30 PM
By auld argonian in forum Professional Kiltmakers Hints and Tips
Last Post: 26th October 05, 10:12 AM
By HeathBar in forum Kilt Advice
Last Post: 28th May 05, 01:53 PM
