Actually, my friend, Graeme, who owns the fine local kilt emporium, Arizona Kilts [shameless plug], contacted the gal who does his kilt alterations & she recommended essentially take the kilt apart, shortening it the desired amount (in my case 2½ inches) from the top & then remaking the kilt.
Since I've taken a fancy to the unique character of this kilt & am already in for a fair amount (£239.50 / $485), I'm seriously considering this course of action.
Happiness? I'd settle for being less annoyed!!!
"I used to be disgusted; now I try to be amused." - Declan MacManus
Member of the Clan Donnachaidh Society
I would leave it as it is a Military Kilt, and a piece of history of sorts, take a look at the rise on this kilt
10th July 07, 07:49 AM
My kilt arrived today firstly i must say the material and workmanship are great it is a light year ahead of the standard issue kilt (pre RRS). This is real value for money
As with previous comments the kilt rise is high but it is exactly the same at the issue kilt I currently have however because the material is far superior it feel less obvious. Interestingly its also the same length as the kilt i got issued in 1990!!
My only problem now is the few (read lots) of fatboy pounds I put on that I need to shed to get into it properly.
What better incentive can you have :-)
10th July 07, 08:17 AM
Thanks for posting the photo again. I had seen the thread on the museum but I didn't pay much attention to the kilt worn by the docent. I will try my kilt on again and compare against his.
I'm going to screw up the terminology so please bear with me...
Shouldn't the military kilt and a "normal" dress kilt have the same "fell" length? The length I'm referring to here is the length of the unsewn pleats. Or is that the "drop" length? AAR, shouldn't that length be the same on the two kilts?
Bruce K.
Laird of Diddly Squat
10th July 07, 09:14 AM
The fell is the sewn part of the pleats. on any trad kilt it should be the same distance from your natural waist to the bottom, but can vary from the waist up depending on the rise the kiltmaker puts into it. The drop is typically from waist to bottom of kilt. The unsewn part of the pleats is called the unsewn part of the pleats, i guess. It sounds right that the unsewn part should be the same length from kit to kilt for a given drop.
I'd agree with the folks above - If you can wear it with the rise as is and have it near top of knee, keep it as is. If you do decide to get it shortened, Have it done at the to so you don't have ot mess with a hem, which would mess up the look of the MBP, IMO.
By Retro Red in forum General Kilt Talk
Last Post: 8th July 07, 08:10 AM
By Nervous Jock in forum General Kilt Talk
Last Post: 10th June 07, 10:03 PM
By orangehaggis in forum How to Accessorize your Kilt
Last Post: 19th May 06, 11:51 AM
By ronstew in forum The Tartan Place
Last Post: 29th April 06, 09:44 AM
By wgority in forum Miscellaneous Forum
Last Post: 2nd April 06, 04:01 PM
