Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    29th May 07
    Rochester NY
    Quote Originally Posted by cacunn View Post
    I put my casual and semi-trad in the gentle cycle of the washing machine, cool or cold water. I do not over load the washer. Once the wash is done, I hang the damp kilt on a hanger and hand/finer press the pleats. I just run the pleats through the palm of my hands, if necessary for I will run a single pleat between my fingers. Let dry an then wear.
    I've had good results so far.
    Thanks for the info. My concern is basically for the leather as my wife has told me that leather shouldn't be put in the washer. I try never to argue or disagree with SWMBO unless I'm real sure of my information.
    Bruce K.
    Laird of Diddly Squat
  2. #22
    30th June 04
    Houston, Texas
    Quote Originally Posted by BruceK View Post
    Ron:
    How easy is it to care for the semi-trad kilt? Can it be washed in the washing me like their casual kilt which does not have the leather and buckles? It's bad enough to dry clean my tanks - I'd rather avoid that with the kilts I wear almost daily if I can.
    Thanks!
    BruceK, Rocky may need to verify this, but if I'm recollecting rightly, you should NOT run a USAK PV kilt to the dry cleaners, as it can strip off the teflon coating.
    Best,
  3. #23
    29th May 07
    Rochester NY
    Quote Originally Posted by Kid Cossack View Post
    Best,
    Ooh! Now THAT is a very useful bit of information. I shall verify with Rocky.
    Thanks!!
    Bruce K.
  4. #24
    6th July 06
    Oxfordshire, England
    One other comment re cleaning PV: I make sure that every little bit of fabric softener is cleaned out of the washing machine before I load my PV kilt and I make sure not to use any during the wash either. Like dry cleaning, the softener will remove the teflon coating.
    I'll just add that wearing a PV kilt in hot weather is a special delight. Knowing that you can just wash it when it gets too sweaty is a bonus.
  5. #25
    5th August 07
    I'm glad I posted this thread.. lots of good information. Thanks to all
  6. #26
    8th February 04
    Thanks for the interesting reading, Ozone!
    To others... Yes, the info on cleaning our Casuals and Semi trads is correct...
    Machine Wash Cold, Hang Dry. Do NOT use Fabric Softener.
    The manufacturer says it can be dry cleaned, but I strongly advise against it as the chemicals used can take the teflon coating off of the material over time.
  1. What is Poly Viscose?
    By setboy in forum Miscellaneous Forum
    Last Post: 10th July 06, 08:53 AM
  2. Speaking of 16 oz Poly Viscose...
    By RockyR in forum General Kilt Talk
    Last Post: 16th January 06, 03:00 PM
  3. Poly-viscose tartan...
    By chasem in forum General Kilt Talk
    Last Post: 28th November 05, 09:51 AM
  4. Poly Viscose... what is it?
    By Jimmy Carbomb in forum General Kilt Talk
    Last Post: 25th August 04, 01:40 PM
  5. Poly viscose
    By Graham in forum Contemporary Kilt Wear
    Last Post: 18th August 04, 02:58 PM
