Results 21 to 30 of 32
  1. #21
    27th September 04
    Amelia County, Virginia, USA
    Like others have said, the traditional kilts are designed to be worn with a sporran. The wider aprons need the weight of the sporran to help push them down when sitting.
    Jerry, Kilted Old Fart.
  2. #22
    18th February 05
    Spokane, WA
    Quote Originally Posted by Jerry View Post
    Dido that! Sporrans serve more than one purpose.
  3. #23
    15th July 07
    California
    Quote Originally Posted by ccga3359 View Post
    Nudge, hey McMurdo we're both one closer to getting our Newsomes. In regards to your concern, are you sure you're not bragging ? As McMurdo said it may just need getting used to. Until that time be careful. Unfortunatly I can't see you pics but I imagine it to be nice.
    Hey Grant - Me too! Matt is doing a Leatherneck box me - Paid for and everything. It should be coming my way............. well sometime.....
    Oh the jonesing!
  4. #24
    Captain's Avatar
    Captain is offline Oops, it seems this member needs to update their email address
    10th August 06
    Royse City, TX, USA
    I think the problem is you are not letting the underapron slide under the overapron. There needs to be separation when sitting. In the Hamish video, when you push down on the apron, it is making the aprons separate, consequently you have more material between your knees.
    I don't know that that's any of my doing... it just seems that the wool holds to the other layers of wool pretty good... I'm hoping it'll smooth out with time... it's a little itchy right now...
  5. #25
    3rd November 06
    Anchorage, Alaska, USA
    Quote Originally Posted by pdcorlis View Post
    It doesn't look too bad, but those of us that own 5 yard kilts have to be a bit careful how we sit.
    Hmmmm . . . I don't have a 5-yard kilt, but I have one of Matt's 4-yard box pleat kilts. Sitting without exposing myself is not a problem. Like someone else mentioned, the underapron slides one way and the outer apron slides the other to drop between my legs - plenty of material there.
    Abax
  6. #26
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    Quote Originally Posted by Mr. MacDougall View Post
    It can not be denied that Matt does outstanding work. I'm just waitin' on my box pleat, with bated breath.
    Working on yours as we speak!
  7. #27
    22nd September 04
    Canton, NC
    Quote Originally Posted by Captain View Post
    Alright... you asked for it...
    The first pic is me right after sitting. The second is after I've pulled and pushed and tried to be as modest as possible. Images are linked so as not to have giant pics of me sitting in my kilt just pop right out on screen...
    http://www.kevindooley.net/images/Cian/IMGP0943.jpg
    http://www.kevindooley.net/images/Cian/IMGP0944.jpg
    If you notice, there's a spot where the fabric bunches up... if that spot was about 4-5 inches lower, I'd have the extra fabric I need for the kilt to drape between my legs...
    Any suggestions?
    Not really. I have the same "problem" and it is only partly due to my waist line having migrated over the years. I have noticed over the last twenty years or so that all lower body garments tend to go north when sitting (which is a hugely good reason to rid ones self of the sort that tend to saw you in twain.) Solution? Nothing that I know of except have your kilts made mid calf length, and neither of us would even give that a fleeting thought. May I suggest some observations of how this sort of thing works? Go to a big mall, the food court say, and watch (as a purely academic exercise of course) how lady's skirts behave as they sit. The knee length variety especially will, without exception, rise quite considerably. This is due to a simple engineering fact of life: if you take an object whose top is at a fixed height and flex the plane the bottom must needs rise.
    Anyway, your new kilt is very nice. I know you will love it for years to come.
  8. #28
    Very sharp looking kilt! I also have a Matt Newsome 5 yarder and I like it just as much now as I did when I first got it in October of 2006.
    As for sitting...
    Here is a bit of advice your kiltmaker wrote on the subject:
    http://blog.albanach.org/2006/06/sit-like-lady.html
    16th December 05
    Maryland USA
    Some woolens are less slippery than others.
    Layers of tightly spun and woven worsted wool
    will slide easily over each other. More fuzzy
    wool will cause the layers to stick together.
    If the underapron is really long, it will drape
    over the left leg and make for even more
    friction. (This extra length of fabric is
    actually good, because it allows for plenty
    of coverage when you sit.)
    The trick to get the coverage you need
    is practice. You need to sit quickly enough
    that the fabric is slightly in motion so the
    layers aren't stuck. Just as you hit the
    chair (slightly after the rear sweep)
    give the apron a quick punch so it drops
    between your legs. At first it will feel strange,
    and probably "ladylike."After doing it enough
    times, it will become second nature, and
    you will do it with enough "authority" that
    it won't look ladylike at all.
  10. #30
    9th June 06
    Airdrie, AB. Canada
    When I sit with my either of my kilts I have to make a conscious effort to make sure I'm decent. When I sit, I sweep my pleats with one hand and push my apron down with the other. The kilt does show more knee when you're sitting; it's normal. The sporran definitely helps too.
    William Grant
    Stand Fast Craigellachie!
  1. Henderson (weathered,) 4 yard, boxpleat by Matt Newsome: A review
    By Tattoo Bradley in forum Traditional Kilt Wear
    Last Post: 29th August 07, 09:15 PM
  2. Review of Matt Newsome 4-yard Box Pleat
    Last Post: 22nd January 07, 02:41 PM
  3. My Matt Newsome 5 yard Knife Pleated Kilt!
    Last Post: 9th October 06, 09:58 AM
  4. 4 yard vs 8 yard - Part Two
    By Blu (Ontario) in forum General Kilt Talk
    Last Post: 23rd May 06, 03:35 PM
  5. Whens an 8 yard ,not an 8 yard ?
    By Freelander Sporrano in forum Traditional Kilt Wear
    Last Post: 12th October 04, 07:48 PM
