16th December 07, 08:43 PM
#21
Thick leather is hard to cut...which is why it is so great for making things that need to withstand such things. If you are going to make one-pass cuts, it will take a lot of force. If that is the case, you have to either use a clamped down straight edge or some kind of jig that helps you control the blade. Remember that force and control are inverse properties here, and a slip could result in a really bad injury. The alternative is to make multi-pass cuts, possible with a smaller blade, and retain safe control of your tool. The downside to this is that the edges you produce may be a bit ragged. Tidying these up with a small sharp blade and/or a rounding tool is not hard. Always opt for control and safety whenever possible.
21st December 07, 09:41 PM
#22
On really thick leather, I will sometimes drill the stitch holes with a drill press, and I have even been known to use a bandsaw to cut the leather- It works very well, and then a belt sander works nice to clean up the edges.
Haxtonhouse
The Fish WhispererŽ
___________________________________________
That which does not kill us makes us stronger.
24th December 07, 06:43 AM
#23
I am the most impatient man on the planet. I have to keep telling my self "many light cuts equals one nice one". Go slow with a sharp knife.
These are some of the stitching tools I use. Tandy closed the store in Manchester so I don't know where to get them now, maybe online. Most good craft stores should have them.
The groover works best on unfinished leather, the star wheel I run along a straight edge. I use a wooden mallet to pound things as it doesn't flare the tool heads. I also second the Tandy book. I have it and it has lots of good info. I'm pretty fortunate to have a friend, also kilted (74th Reg O' Foot - Highland) who makes shoes for museums and he's very free with his advice. I'm just a hacker but by the photos here I can see that there are some real craftsmen online and it appears that they are also willing to help out .
Bob
24th December 07, 07:18 AM
#24
 Originally Posted by Amoskeag
I think I understand that the tool on the far right is used to punch regular slots in leather for lacing.
Is there any advantage to drilling over punching?
24th December 07, 07:30 AM
#25
Oops. Sorry, that's correct.
My experience has been that the tool is quick and uniform and makes wider holes for the saddle stitch. The drilled holes gives a nice effect with the round hole and in many instances I like it better. It's time consuming but then all good craftsmanship is.
Bob
24th December 07, 07:35 AM
#26
So what's the use for the one on the far left? The "star wheel?"
24th December 07, 11:20 AM
#27
That's how you know where to drill the holes You roll it along (merrily?) and then drill out the dimples
Bob
25th December 07, 06:22 PM
#28
HMM. Star wheel. . . .never heard it called that before. I usually use a no. 6 overstitch wheel, which i believe is the proper name. Sorry, the correction is not to be pompous. . . I am new to leather workin myself, I just found it amusing. About the groover. . . . What is the best tool for marking out the line you want to stitch an even distance from the leathers edge?
28th December 07, 05:32 PM
#29
berserkbishop have you stopped by the Tandy Leather store in Springfield. They should be a good source of material and information.
The Leather Factory #08 SPRINGFIELD
Toll Free: 800-888-1993
Manager: Larry Bartels
2341 E Kearney Springfield, MO 65803-4970
springfield@leatherfactory.com
417-862-8669 fax: 417-862-6952
By mano1979 in forum Professional Kiltmakers Hints and Tips
Last Post: 22nd December 08, 06:14 PM
By ChromeScholar in forum DIY Showroom
Last Post: 6th August 07, 06:26 PM
By longshadows in forum Kilt Advice
Last Post: 3rd April 06, 09:16 AM
Last Post: 25th August 05, 12:50 PM
By emeraldfalconoflight in forum Kilt Advice
Last Post: 11th August 05, 07:41 AM
