Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Coyote Pelt
  1. #21
    22nd November 07
    US
    Quote Originally Posted by James MacMillan View Post
    I have a self trapped and skinned skunk skin, that is a work in progress, that may someday make a passable evening sporran.
    Someone was just asking me how you get the ferret smell out of a skunk fur hide. I told her I had no idea because I've never delt with skunk hide.
    Dingo sporran sounds interesting... What's dingo hide like and are you talking about a fur sporran? Good luck, let us know how it works out.
    * And I see your answer James. I guess maybe she got a little spray or something when she got the skunk. I didn't think of that because she was talking about the ferret smell, so I thought they had that smell all the time. I will tell her to give it the standard tommader skunk spray bath, LOL.
  2. #22
    15th July 07
    California
    Someone was just asking me how you get the farrit smell out of a skunk fur hide. I told her I had no idea because I've never delt with skunk hide.
    Unless the skunk sprayed while it was being killed, there is no smell. If there is, tomato juice works well. Not ketchup. But, really skunks don't smell bad, only their spray, if that makes any sense.
  3. #23
    7th July 06
    Roswell, Georgia USA
    Find the taxi-man. Make sure he understands what you intend to use it for so he uses extra care to preserve the face in skinning and tanning. Yes, you can get a pelt online at a reasonable price, but unless you can inspect it you take pot luck on what the face looks like.
  4. #24
    Faced with a dead coyote I would probably have a go at skinning it, unless it was unhealthy, scabby looking or otherwise looking dangerous. I'd probably get a couple of pairs of gloves, some thin surgical ones and heavier working waterproof ones, and maybe a face mask and disposable overall. I'll tackle most things but there is no sense taking stupid and easily avoidable risks.
    I would aim to remove all the main body and upper parts of the legs, but only after giving it a good hose down, or even a brief bath, and letting it drip and cool - most surface parasites seem to leave things that have died so leave a container underneath to catch - and hopefully contain and drown anything washed off or taking a leap off the corpse.
    I'd hang it up, (though I'd have to use a pulley and rope first to lift that weight but second to minimise contact) hose off, leave to drip, dispose of first drippings, hose down again with particular care to wash over the head and inside the mouth at low water pressure - that is -
    AT LOW WATER PRESSURE - note the emphasis
    You don't want to be creating a toxic aerosol to breath in or a spray to wet your skin.
    To peel it, I'd take it down onto a bench or the floor, so it was not stretched out in its skin, lay it on its back and pinch up and make a small snip with sharp scissors in the middle of the belly, just through the skin. Lift the skin up away from the internal covering of the gut (which you will regret puncturing) and cut from the first incision towards the throat keeping to the mid line of the body, then cut down towards the back end. Cut around each side of the genitals and anus then pull the skin a little way up the tail without cutting the tube of skin, and chop through the bone of the base of the tail.
    Now pull the tail towards the head to loosen the skin on top of the hip girdle and loosen the skin around the top of the legs so the inside is sliding out of the skin backwards. Push the legs so they fold up at the joints and keep pulling the skin forwards and away from the underneath. If you need to cut through tissue connecting the skin to the carcase fold the skin back and slide the knife in away from the skin, cut through the connecting strands ALWAYS away NEVER towards either its skin or your own.
    Once you get the skin tube off the upper part of the leg pull it off inside out down to the thin part of the leg - then cut through the flesh and bone leaving the paw inside the skin. Once you have the hind legs out strip off the skin up to the neck and cut through the neck of the carcase, then pull out the front legs and cut off the paws at the wrist, leaving them inside the skin.
    It is now possible to throw away the majority of the animal, and I'd sprinkle salt on the inside of the skin and put quite a lot in the mouth after removing the tongue - assuming that is not wanted.
    The inside layer of the skin will be fatty and probably have a few veins, and it is removed when the skin is cleaned, but it can get a bit manky if there is a delay between skinning and cleaning. The salt will help preserve it. It might take some time for the fur to dry completly, so hanging it up in a dry place for a day or so, rather than packing it up straight away would be sensible.
    It might take some persuasion to peel off the skin from something getting slipperier by the minute - it might help to put a slip knot of strong rope around the haunches once they are stripped off and anchor them so you can pull at the skin more easily. The amount of cutting of connecting tissue and the amount it will give to persuasion depends on the animal and how strong your hands are.
  5. #25
    13th June 07
    Hoschton, GA
    13 Post(s)
    skinning
    wow, thank you, I'll let you know how it turns out!
    “If you want people to speak kindly after you’re gone, speak kindly while you’re alive.”
    Bob Dylan
  6. #26
    22nd November 07
    US
    Don't know if it's been brought up, but if you're going to shoot the thing to skinn it for a pelt, use a smaller shooting device. A big one might not leave much... carcus in tact. You know what I mean. Good skinning luck.
  7. #27
    29th January 06
    Asheville, NC
    David, a couple of things.
    Coyotes, live, dead, or in between, STINK. You're considering a really smelly chore, and one that your wife/family/freezer will not soon let you forget. (Trust me on this...much personal experience!)
    Tanning a hide will cost a fair amount. You'll never be able to have it done for less than you can buy a tanned pelt from a dealer.
    "Home brew" tanning is not cheap and provides iffy results at best.
    Here's another source of pelts worth looking at: http://www.clearcreektrading.com/index.html
    I was in their place this summer and the quality and prices are both excellent. They stock far more than they show on the web catalog, so call them and tell them what you're looking for and they'll do their best to help you. They're good folks.
  8. #28
    5th September 05
    Chicago
    I didn't know some of the things that Tartan Hiker mentioned but I'm taking him as an authority.
    Here's another source if you decide that it's easier to just buy one:
    http://leatherunltd.com/leather/skins/skins.html
    Best
    AA
  9. #29
    22nd November 07
    US
    Tartan Hiker probably has the right advice. I would be worried about the safety issues on top of that. It's kind of icky though. Nothing against the tanners, some of my best friends do that, eewoo ick. It's not like getting a turkey at the grocery store.
  10. #30
    5th September 05
    Chicago
    I mean, I don't want to be an alarmist...but is there a real possibility of rabies involved? I just have it on my mind these days because I'm getting active in wildlife rehabilitation and may have to start getting innoculated in order to be able to handle some of the critters that we encounter.
    Best
    AA
  1. Fur/Pelt sporrans
    By rmmcscott in forum DIY Showroom
    Last Post: 13th October 07, 11:35 PM
  2. DEKS on coyote ugly.
    By Warlock in forum Kilts in the Media
    Last Post: 14th May 07, 08:23 AM
  3. animal pelt sporrans
    By Magnus Sporrano in forum USA Kilts
    Last Post: 27th May 05, 06:05 AM
