I went out last night in about 90 degree heat, and here in South Carolina we have bad humidity, I mean you can taste it most times. But my Sport Kilt Irisher was very light and cool. I sweat a bit where my belt was, but hey, that was expected. I think I wont wear a belt when it's that hot anymore.
Ok, So its like 92 deg and 85% humidity. how do you guys not sweat your butts off?
Have a very large butt.
I was just wondering if you all had any ideas of keeping cooler, or not sweating your kilts out.
Yeah; in the heat, cotton drawers are more comfortable than reggie.
A rub of something like Secret invisible antiperspirant between the thighs helps a little.
If you must wear hose, get really cheap thin ones. I've got some from Sport Kilts that are (relatively) quite comfortable yet presentable.
Avoid having to wear a jacket if at all possible. As a piper, I can't always do that, so I at least minimize the amount of time I wear it to only when I'm being paid to.
I find so-called Jacobite shirts to be a lot hotter than a short-sleeve Oxford, tropical uniform shirt, or polo shirt.
Situational awareness; always know where the shade is. Go stand in it; it's amazing how much cooler you'll feel.
Hydrate, hydrate, hydrate.
Always at least air out/air dry your kilts before hanging them back up in the closet, perhaps folding a dryer sheet into it when you clip it into the hanger.
What he said! first, last, and always.
Be like these guys (intelligent):
Poly-cotton! I did an 11-mile, 3,000' elevation gain hike on Thursday, temps in the low 90's most of the day (which is really unusual for this area). 5.5 yard poly-cotton desert camo kilt and 25+ pound pack. My t-shirt was soaked for most of the day, but I was cool and comfortable elsewhere. Body glide!
Today's high is forecast to be 103F, with high humidity. The heat index by 1PM is forecast at 116F (Fourth straight day over 100F).I will be wearing an older model Sportkilt. However, I'll try to stay inside where my overworked AC unit will be struggling to keep the temperature around 80F. The electric bill for this month will probably be as much as a well made heavyweight kilt.
Jerry, Kilted Old Fart.
Wear sunscreen. You'll feel cooler because you're not covered in second degree burns.
Untuck your shirt. It helps ventilate you.
Wear sandals. You lose a lot of heat from your feet.
As a dancer I'll sweat gallons even indoors. I find that wool hose make a BIG difference in whether you're hot or just warm. I like cotton hose for just casual wear, but they'd pass for semi-formal. You can always do soccer socks as well and that will help. Also, don't wear a wool bonnet... that just keeps the heat in! My Balmoral is black which makes it even worse in the sun.
8th June 08, 07:25 PM
Did some B-B-Que today. Wore my Utilikilt original and sandles with a sleveless tee shirt. was comfortable enough.
By Retro Red in forum Miscellaneous Forum
Last Post: 20th July 07, 06:47 PM
By Corvidae in forum Kilt Advice
Last Post: 6th February 07, 09:08 AM
By jjoseph in forum How to Accessorize your Kilt
Last Post: 10th July 05, 06:49 AM
