18th December 08, 01:12 PM
I was referring to the thin black lines in the middle, NOT the big thick black lines.... that's where we got confused.
Here's the question though... why isn't it an 'ABAC' tartan? I photoshopped (poorly) your pic and here's why I thought it would be ABAC:
18th December 08, 02:09 PM
I believe the answer is that the A must be a pivot (mirror image when folded at the line). B in you pic is not mirrored when you fold it, one side has green, one is blue. Could be wrong but it makes sense to me.
edit: Chase beat me by two mins.
Wallace Catanach, Kiltmaker
18th December 08, 02:07 PM
Rocky, in your edit, as you go out from the center stripe in your black A section, the thread count is different from the other two A sections. They're the same for a bit (K4 B4 SL52), but from there on, they're different.
Barb said: "In order to be a pivot, the colors need to be identical in sequence and width on each side of the pivot."
So while each of the As in your edit is a pivot, they're not identical pivots, and B/C wouldn't be pivots at all. And so, I think, B and C wouldn't be "color blocks" for the sake of finding the pattern.
Correct me if I'm wrong, Barb, or help me out if I'm explaining poorly.
18th December 08, 02:24 PM
But by that logic (folding on the thin black line), Blac Watch wouldn't be 'ABAC' either... if you fold Black Watch on the black line in the middle of the green, it won't be identical on both sides either...
Chattan... my point is that A is the pivot (either 'A').
My brain hurts now. Think I should take a nap and stop nit-picking. ;)
18th December 08, 05:51 PM
touche. That's a good point. I'll hold out for further explanation from Barb then.
18th December 08, 05:43 PM
To me it just looks like a particularly wide sett, giving the appearance of asymmetry, when it is just not common to our eye and hard to recognize as a repeating pattern. I saw it, but I had to look for a long time before I could see it. The letters didn't really help, I'm afraid to say.
Rex.
18th December 08, 05:53 PM
Oops, sorry, I'll take that out untill Barb explains about the Black Watch.
19th December 08, 06:24 PM
Well, I guess I look at the A elements of the Black Watch (the narrow black stripe in green), and I see them as distinct elements that have local symmetry (although only B and C are actually pivots). You _could_ actually define the Black Watch as an AB tartan if you started and ended the A and B blocks in the center of the narrow black stripe in green.
To me, it's useful, though, to think of the Black Watch as ABAC and to call out the A blocks because it's so easy to misidentify the sett.
You could call any tartan an ABAC tartan if you wanted to chunk out a piece between the A and B sections, but it doesn 't strike me as being very useful if it isn't a distinct element. In the case of the Black Watch, the A block is a locally symmetrical part of the tartan that _looks_ like it ought to be a pivot. In the case of the MacNaughton, the heavy black stripes to me are just part of the A or B block.
But, maybe Matt can weigh in on this.
20th December 08, 07:30 AM
I think I see what you mean... the "dark" sections of BW are 'symetrical in and of themselves while the "sections with the thick black line" in the MacNaughton are NOT symetrical in and of themselves.
20th December 08, 09:31 AM
Yup, that's what I meant. In reality, you could assign a letter to every single element and represent the tartan as ABCDEFGFEDCBABCDEFG...... (which is essentially what the sett abbreviation is). If you called this an AB tartan, you'd group some of the individual elements (maybe A=A+B+C+D and B=D+E+F+G).
But what if you had a tartan where the elements were BAB CDEDC BAB FGHGF BAB CDEDC
It could be AB, if A= 1/2A+B+C+E+D+C +B + 1/2A, and if B = 1/2A B+F+G+H+G+F+B+1/2A
But it might be more useful to lump a little differently and call it an ABAC, where A= B+A+B, B=C+D+E+D+C, and C=F+G+H+G+F
Wow - is that confusing, or what???
By Tommy Hunt in forum General Kilt Talk
Last Post: 18th October 08, 05:58 PM
By zeeew in forum Kilt Advice
Last Post: 27th July 08, 12:48 PM
By MacWage in forum General Kilt Talk
Last Post: 20th July 07, 09:21 AM
By Moosehead in forum General Kilt Talk
Last Post: 8th February 06, 06:06 PM
